Roberto
Are there any plans to add the Water level expansion to the internal memory section of the portal?
Water level expansion settings via Portal
Re: Water level expansion settings via Portal
It's been logged and I'll try to get it in on the next update.
What would you put there? The waterlevelato settings?
I think he's talking about plotting the water level on the web chart?
Maybe, but he said under InternalMemory.... if you need the web chart, you can use this
http://forum.reefangel.com/status/chart ... &filter=wl
One of my favorite charts
I would like to see both.What would you put there? The waterlevelato settings?
It would be a help when adjusting the sump level for my skimmer to be able to set the water level sensor via the portal on my iPad while by the sump. Rather than having to change the hard coded values, if they were in internal memory I could do it on the fly.
Cool. Taking that a step further with the salinity module, you could adjust the wl ato settings with that info as well...hmmm
