Hi,
Is there a way to rename the PWM Channels - From Actinic/Daylight to something else? It will be easier to determine.
I'm currently using 1 of the channel to control my Tunze powerhead.
I will be using the other channel to control my Tunze Wavebox soon.
~JaY
Rename PWM Channels
Rename PWM Channels
They aren't really named.. Thats the name of the function..
You could write a wrapper function to call the real one..
void SetTunze1(int speed) {
SetDaylight(speed);
SetDaylight(speed);
Re: Rename PWM Channels
I'm not sure what you mean - I'm new to this & not a programmer either.
If u don't mind, can u please explain?
Rename PWM Channels
What are you looking to rename? On the portal? Android app?
These can not be changed...on the other hand if you want to reference it in your code by a different function instead of SetDaylight or SetActinic then you can use the function I gave you and paste it at the end of your INO file. Then use SetTunze1 instead of SetDaylight...
Portal -
PWM Channels
Actinic
45 %
Daylight
30 %
PWM Channels
Actinic
45 %
Daylight
30 %
