Charts and 0 values
Related to the Portal
Charts and 0 values
I understand not storing 0's in the DB and all, but when charting values and you get a 0 value, the charts on the portal don't reflect the time between where the 0 values are... So for instance. Moon rise / set, looking at PWMA, it looks like it immediately drops to 0 and then comes back up again, despite there being ~12 hours between the rise and set. Is there anything that can be done so if an interval is 0 the duration of time is shown properly in the chart?
Re: Charts and 0 values
Well, it will show 5 minutes prior and 5 minutes past, right?
Or am I not following?
Take the example for rise/set time. In the PWM view yes you will see the 5 minutes prior and past, but you won't "see" the duration to scale with the rest of the data. So what only looks like an instant was 10-12 hours...
Oh, I see what you mean now.
It should show the timeline properly, but it is not doing it.
Need to investigate.
