What's going on for forum/portal?
When the portal/forum have been down, my controller is going apeshit. Constantly doing a reset, when in turn stops my return & skimmer pump while their ports are delayed. Causing tons of water level fluctuations and loud scary bubbles that scare the fish.
Sunday around 3am it happened, and this morning around 6am until around 1130am EST.
I don't understand why the forum/portal being down would affect the RA, but I need to figure it out so it stops resetting all the time.
Not sure why thats happening, but i don't recommend delaying your return...can i ask why? For another user we found a good workaround.
Re: What's going on for forum/portal?
I have 3 flow pumps, so I have those start first, to get the levels between the display area and the pump area in the rear. Also after feeding I like the return delayed so food doesn't get sucked into the pump right away.
I hear ya..and sorry this is off topic. For the return pump, i recommend extending the feed timer to the time you want return pump off for, and then during your feed mode we can kick on the other flow pumps to match what your doing today.
Doesn't help with your issue overall, but would address return pump being down unintentionally.
As far as the apeshit part, can you post your code? Just want to make sure nothing in there would interfere with portal.
No problem going a bit off topic. That would be cool adjusting the feed mode for the return pump.
//--------------------------------- Place global variable code below here ---------------------------------
boolean PowerOutage=false;
boolean DelayedPowerOutage=false;
// Globals for Params on Custom Main
byte x,y;
//--------------------------------- Custom Menu ---------------------------------
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Turn Lights On";
prog_char menu1_label[] PROGMEM = "Turn Lights Off";
prog_char menu2_label[] PROGMEM = "Start Feeding";
prog_char menu3_label[] PROGMEM = "Start Water Change";
prog_char menu4_label[] PROGMEM = "Clear Overheat";
prog_char menu5_label[] PROGMEM = "Calibrate pH";
prog_char menu6_label[] PROGMEM = "Display Version";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label };
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Item 1");ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
for ( byte i = 0; i < MAX_RELAY_EXPANSION_MODULES; i++ )
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Item 2");ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
void MenuEntry3()
ReefAngel.DisplayMenuEntry("Item 3");ReefAngel.FeedingModeStart();
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Item 4");ReefAngel.WaterChangeModeStart();
void MenuEntry5()
ReefAngel.DisplayMenuEntry("Item 5");ReefAngel.OverheatClear();
void MenuEntry6()
ReefAngel.DisplayMenuEntry("Item 6");ReefAngel.SetupCalibratePH();
void MenuEntry7()
ReefAngel.DisplayMenuEntry("Item 7");ReefAngel.DisplayVersion();
//--------------------------------- End Custom Menu Globals ---------------------------------
//--------------------------------- Place global variable code above here ---------------------------------
//--------------------------------- Begin Custom Main ---------------------------------
ReefAngel.LCD.DrawDate(5, 2);
// Display T1 Probe Value
ReefAngel.LCD.DrawHugeNumbers(COLOR_CRIMSON, 255, 5, 14, text);
// Display pH Text
ReefAngel.LCD.DrawText(COLOR_INDIGO,255,80,14,"pH");
// Display pH Value
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 95, 14, text, Num8x16);
// Display T3 Probe Text
ReefAngel.LCD.DrawText(COLOR_ROYALBLUE,255,80,24,"Rm");
// Display T3 Probe Value
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_ROYALBLUE, 255, 95, 24, text, Num8x16);
//Moon Phase
ReefAngel.LCD.Clear(DefaultBGColor,5,88,95,95);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,5,88,MoonPhaseLabel());
//Dimmable Moon LEDs
ReefAngel.LCD.DrawText(COLOR_NAVY,255,5,98, "MoonLEDs:");
ReefAngel.LCD.Clear(DefaultBGColor,59,98,75,106);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,59,98, ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,75,98, "%");
// Display Main Relay Box
ReefAngel.LCD.DrawOutletBox( 2, 107, TempRelay );
// Display Expansion Relay Box 1
ReefAngel.LCD.DrawOutletBox( 2, 119, TempRelay );
//--------------------------------- End Custom Main ---------------------------------
//--------------------------------- Begin Setup ---------------------------------
// Initialize the menu
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit; //Flow1&3,Return,Skimmer
ReefAngel.FeedingModePortsE[0] = Port2Bit | Port6Bit; //FrontT5,Heater
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit; // Flow1-3,Return,Skimmer,DispHeater
ReefAngel.WaterChangePortsE[0] = Port2Bit | Port3Bit | Port6Bit; //Front+BackT5,SumpHeater
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port3Bit; //Center+Front+BackT5
ReefAngel.OverheatShutoffPorts = Port6Bit; //DispHeater
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port3Bit | Port5Bit | Port6Bit; //Front+BackT5,FugeLight,SumpHeater
//--------------------------------- Place additional initialization code below here ---------------------------------
ReefAngel.Timer[1].SetInterval(5);
//--------------------------------- Place additional initialization code above here ---------------------------------
//--------------------------------- End Setup ---------------------------------
//--------------------------------- Begin Loop ---------------------------------
ReefAngel.Relay.On( Port1 ); //Flow1
ReefAngel.Relay.On( Port2 ); //Flow2
ReefAngel.Relay.On( Port3 ); //Flow3
// Ports that are delayed on Power Cycle & Feeding & Water Change
if (PowerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
PowerOutage=false;
LastStart=now();
ReefAngel.Relay.DelayedOn( Port4,4 ); //Return
ReefAngel.Relay.DelayedOn( Port5,10 ); //Skimmer
// Heaters
ReefAngel.StandardHeater( Port6,770,774 ); //DispHeater
ReefAngel.StandardHeater( Box1_Port6,768,772 ); //SumpHeater
// StandardHeater2( Box1_Port6,768,772 ); //SumpHeater
// T5 Light Schedule
ReefAngel.StandardLights( Box1_Port1,8,0,20,0 ); //CenterT5 8a-8p
ReefAngel.StandardLights( Box1_Port2,10,0,18,0 ); //FrontT5 10a-6p
ReefAngel.StandardLights( Box1_Port3,10,30,18,45 ); //BackT5 1030a-645p
// RSMLED Moonlight Schedule
if (hour()>=6 && hour()<=8) ReefAngel.StandardLights( Box1_Port4,6,0,7,59 ); //RSMLED Morning 6a-8a
else if(hour()>=20 && hour()<=23) ReefAngel.StandardLights( Box1_Port4,20,0,23,45 ); //RSMLED Evening 8p-1145p
else if(hour()>=23 || hour()<=4) if (MoonPhase()>=69) ReefAngel.StandardLights( Box1_Port4,23,46,4,0 ); //RSMLED on for Full Moon 10p-4a
// Fuge Light Schedule
ReefAngel.StandardLights( Box1_Port5,0,0,8,0 ); //FugeLight 12a-8a
// PWM Dimmable Moonlights Schedule
if (hour()>=21 || hour()<4) // Turn Dimmable Moonlights on 9p & off 4a
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
//--------------------------------- Place your custom code below here ---------------------------------
// Turn on Fuge light during water change mode
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) ReefAngel.Relay.On(Box1_Port5);
// Power Outage - Only Flow2 port on
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)) PowerOutage=true; //Exp1 Relay NOT present
if (!PowerOutage)
ReefAngel.Timer[1].Start();
if (ReefAngel.Timer[1].IsTriggered())
DelayedPowerOutage=true;
if (DelayedPowerOutage)
ReefAngel.Relay.Off (Port1); //Flow1
ReefAngel.Relay.Off (Port3); //Flow3
ReefAngel.Relay.Off (Port4); //Return
ReefAngel.Relay.Off (Port5); //Skimmer
ReefAngel.Relay.Off (Port6); //Heater
// Skimmer off when Return pump is off.
if (bitRead(ReefAngel.Relay.RelayMaskOff,3)==0) //Return
bitClear(ReefAngel.Relay.RelayMaskOff,4); //Skimmer
//////////// Place your custom code above here ////////////
ReefAngel.Portal( "modulok" );
//--------------------------------- End Loop ---------------------------------
/* // Sump Heater Use Sump Temp Probe
void StandardHeater2(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor temperature >= HighTemp - turn off heater
Nothing obvious why portal being down would make the thing go crazy... unless some setting on the wifi module.
I'll try and post some code to change the return pumps to non-delay and the flow to start before feeding timer ends so you at least won't lose your return pump in the future...
Cool thanks.
It's definitely doing a full reset, because I changed the return port to ON from auto and it still was stopping. I could do a test later tonight and see if killing my modem or the RA wifi unit kicks a reset in motion.
Here's the relevant code I added. I found a bug that was in Paul's code, so you should be good to go. It will currently turn your pumps back on 4 minutes before the feeding timer ends. You can increase your feeding timer 4 minutes to compensate if you like.
Here's your full ino with the changes made and changes to feeding ports as well.
ReefAngel.Relay.On( Port4 ); //Return
//Feed Mode Delay on Pump
static boolean feeding=false;
static unsigned long feedingstarted = now();
if (!feeding)
feeding=true;
} else {
feeding=false;
int pumpdelay=InternalMemory.FeedingTimer_read()-240; // 4 minute delay
if (now()-feedingstarted<=pumpdelay) {
ReefAngel.Relay.Off( Port1 ); //Flow1
//ReefAngel.Relay.Off( Port2 ); //Flow2
ReefAngel.Relay.Off( Port3 ); //Flow3
byte x,y;
void MenuEntry1()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry2()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
// Display pH Text
// Display pH Value
//Moon Phase
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit; // Return,Skimmer
if (!feeding)
feeding=true;
} else {
feeding=false;
PowerOutage=false;
LastStart=now();
// Heaters
if (!PowerOutage)
That's awesome Lee. Thanks so much for the code. I will hopefully be able to try it tomorrow night, I don't feel like playing with code at this hour of the night.
Ok I finally got a chance to add the code. Only problem is flow 1 and 3 don't start up right away.
Sent from my mobile communication device
Change the declaration for the static boolean feeding to true instead of false and the default for feedingstarted to 0 instead of now().
That way it wont default to feeding mode when it starts up.
OK, that is working well now. Thanks for the help!
I am guessing I was the only one to have the issue of the forum being down and my RA resetting itself. Or the forum has been up for the last few weeks without being down.
I haven't seen the forum down...
I did experience an issue where the RA reset itself when the wifi module was *disconnected* from the unit; probably is related to what you experienced.
I'm guessing it was the watchdog timer causing this to happen, but I didn't see anywhere in the code that should lead to this condition.
Current setup:
60g 24" custom cube (fish and softies right now)
AI Sol Blue, Ecotech MP-10wES
Coralife skimmer
100% customer controller, transitioning to ReefAngel
Coralife skimmer
There was a day where the portal was down for a little while...otherwise quite stable (knock on wood)
