Change the declaration for the static boolean feeding to true instead of false and the default for feedingstarted to 0 instead of now().
That way it wont default to feeding mode when it starts up.
What's going on for forum/portal?
Re: What's going on for forum/portal?
OK, that is working well now. Thanks for the help!
I am guessing I was the only one to have the issue of the forum being down and my RA resetting itself. Or the forum has been up for the last few weeks without being down.
I haven't seen the forum down...
I did experience an issue where the RA reset itself when the wifi module was *disconnected* from the unit; probably is related to what you experienced.
I'm guessing it was the watchdog timer causing this to happen, but I didn't see anywhere in the code that should lead to this condition.
Current setup:
AI Sol Blue, Ecotech MP-10wES
Coralife skimmer
Coralife skimmer
There was a day where the portal was down for a little while...otherwise quite stable (knock on wood)
