Port forwarding Airport Extreme
Related to the Portal
Rodasphoto
Post by Rodasphoto »
Can someone please help me setup portal so I can control my RA outside of my home. What specifically do I need to put in Public UDP ports, Public TCP ports, Private UDP ports, and Private TCP ports? Do I have to configure anything else? (because I have a dynamic ip address.)
Re: Port forwarding Airport Extreme
Rodasphoto
Put 2000 for each field and when I checked to see if the port was open it still was closed.
Rodasphoto
Fixed it. I typed in the wrong private address. Rimai again thanks for your prompt help. I am extremely happy with RA.
