The RA code you are using.
The WAN ip address can be found here:
Portal Test Open But Still have unreachable address
Re: Portal Test Open But Still have unreachable address
Sorry had long day in the kitchen little brain dead. I'm using the preloaded code haven't changed it yet. Is the wan ip the ip that pops up when you go to http://www.yougetsignal.com/tools/open-ports/? The remote address? A number like 74.133.xxx.xxx?
Oh, now that makes sense...
Create a code with the wizard and make sure to select wifi attachment and make sure that you put your forum username when asked.
