You can see attached picture....
in user control panel i used joaocdestro.asuscomm.com:2000... but just after few minutes portal changed to my actual IP... resulting in lost contact after 1 day.
Portal Changes my DDNS to -> IP after 1 day lost conection
- portal reef angel.png (18.02 KiB) Viewed 2488 times
Regards,
Joao C. Destro
Joao C. Destro
Re: Portal Changes my DDNS to -> IP after 1 day lost conecti
The portal updates itself everytime it receives data from your controller with the wan ip address you are sending it from.
But Roberto, after one day my ISP changes my IP, losing connection... there is some solution?
I want to let in there my ddns... joaocdestro.asuscomm.com:2000
Regards,
Joao C. Destro
Joao C. Destro
If the ISP changes the ip, the controller would send the new ip when it changes it.
It is constantly changed everytime the controller sends data, which is every 5 minutes.
The ip in the portal and whatever your DNS is resolved to, should be the same.
