RA Visuals
Related to the Portal
Re: RA Visuals
Can't get it to work. I think it has to do with the address. I think I need a page on the camera that I don't know the name of.
Here's what the manual says:
For Java mode: http://camera_ip_address/tvjview.htm
For ActiveX mode: http://camera_ip_address/tvaview.htm
Either of these compatable?
Re: RA Visuals
Yes. use the java version....
Looking at your other post:
http://cosmith71.no-ip.net:8080/tvjview.htm
I wish my camera had a streaming view without buttons like yours :(
RA Visuals
Depends on your browser? Java *should* be x-platform...
Is it a dlink..for embedding you may have to use the static image.
Re: RA Visuals
OK, got it Roberto. I thought I had tried that. It's working. However, the image is a little too big and has scroll bars. Any way to fix that?
Thanks again. This is awesome!
Re: RA Visuals
Yeah, mine is dlink and actually uses the same java applet as cosmith71....
<applet name="cvcs" codeBase="http://cosmith71.no-ip.net:8080" archive="aplug.jar" code="aplug.class" width=640 height=480>
<param name="RemotePort" value=8080>
<param name="Timeout" value=5000>
<param name="RotateAngle" value=0>
<param name="PreviewFrameRate" value=2>
<param name="Algorithm" value=2>
<param name="DeviceSerialNo" value="">
</applet>
I wonder if all cameras can use this applet... :?:
Re: RA Visuals
Mine isn't a dlink, it's a TrendNet. Would be nice if it's universal.
RA Visuals
For the dlink i have a html wrapper that loads the static image and refreshes every 2 seconds. I can share the code if anyone needs it, but you need a place to host it..
Re: RA Visuals
You might as well use the java applet in your wrapper instead of 2sec refresh...
RA Visuals
The java applet doesnt work on ios nor through my office proxy :)
This one does both.
Re: RA Visuals
touché :)
Re: RA Visuals
kirkwood wrote:Can an IP video camera be integrated into the Portal?
See what you did? From suggestion to reality in a few hours. :mrgreen:
RA Visuals
Roberto, i think the default portal page is getting that 404 in the webcam frame...unless its a cache issue..
Re: RA Visuals
I'm able to connect just fine.
Can someone else also check?
Re: RA Visuals
I also added the width and height to the settings.
Re: RA Visuals
Thought I had replied...
Portal is working fine for me.
Had to do some playing around with the size to get rid of the scroll bars. I ended up at 654x504 for 640x480 (supposedly) image. Any less on either number and I get both scroll bars. I'm guessing it adjusts the numbers you put in for aspect?
Re: RA Visuals
Yeah, I tried on my ipad and it's fine. My IE at work still shows the 404, but whatever..stupid internal proxies :)
kirkwood
Re: RA Visuals
Post by kirkwood »
cosmith71 wrote:Can't get it to work. I think it has to do with the address. I think I need a page on the camera that I don't know the name of.
what camera are you using?
kirkwood
Re: RA Visuals
Post by kirkwood »
wow.. that is very cool... and all that before I even own a RA.. but I am now proud to say I purchased my RA+ this morning..
but now I have to add an IP camera to my want list...
Re: RA Visuals
TrendNet TV-IP751WC. Tigerdirect had it on sale for $30 last week.
RA Visuals
Congrats and welcome, and you've experienced the full RA support already!!!
I use the dlink dcs camera, i forget which model, but it was like $50
kirkwood
Re: RA Visuals
Post by kirkwood »
i will have to keep an eye out for another deal like that... can you post a pic of how you mounted the camera? can you move and zoom the camera remotely?
Re: RA Visuals
This particular camera doesn't have a pan function on it. It has a digital zoom, but I haven't really used it.
I used a flexible suction mount.
Here's the ebay link:
http://www.ebay.com/itm/190618305920?ss ... 1497.l2649
RA Visuals
I have the same mount..you should look into the fisheye lens too for $20.
http://forum.reefangel.com/viewtopic.php?p=14863#p14863
And i have before / after shots a few posts after..
Re: RA Visuals
Thanks for the links, Lee. I totally missed that thread. I'll look into a fisheye lens, too.
Re: RA Visuals
I'm looking at the D-Link DCS-900 Web Cam that lnevo said he is using.
I wanted to know a good, preferably free dynamic DNS service.
I think someone mentioned No-IP.com
Re: RA Visuals
Sacohen wrote:I'm looking at the D-Link DCS-900 Web Cam that lnevo said he is using.
Yes, no-ip.com is a good, free dynamic dns service. I use it along with dyn.com (DynDns) but they are making it more difficult for the "free accounts" to exist. I would use no-ip.com if it were me.
Re: RA Visuals
Thanks Binder.
