RA Visuals
RA Visuals
Can anyone post a video or pic of what it looks like when you access the RA from your computer or android device?
RA Visuals
look at the Android Reef Angel Status thread. I have posted lots of pictures and a video or two of the app in action. some may be a little old, but the concept has remained the same.kirkwood wrote:Can anyone post a video or pic of what it looks like when you access the RA from your computer or android device?
Re: RA Visuals
The portal can be accessed right now.
Logout from the forum and you will see a sample of how it would look like.
Re: RA Visuals
I apologize for my very basic requests, because the more I type these posts the more I feel like an idiot. So I thank you for bearing with me as I put the pieces together on how I can wirelessly utilize the RA on a daily basis. I have a couple more questions on the tech compatability side.rimai wrote:The portal can be accessed right now.
1) So the Portal is where you go to access your RA? I would be able to turn things on/off here?
2) I will be accessing from a work computer, if I am currenly pulling up the portal does that mean I won't have any issues accessing my personal RA? (i'm thinking about security or something preventing me)
3) Is there any way I can check my droid to make sure there aren't security blocks preventing me from accessing the RA? (i use a droid and it is a work phone so I don't have as much control as a personal phone)
4) Is there anything I need to verify on my router to make sure that it will work with the RA Wifi attachement?
Re: RA Visuals
You can use Portal, android app, java status app, gadget, Client Suite:
Check the contributions page:
http://reefangel.com/download.aspx
Re: RA Visuals
Can an IP video camera be integrated into the Portal?
Re: RA Visuals
Not today. I've been slowly building my own html frontend where i can put a dashboard, my video feed, and my customized controls.
Re: RA Visuals
I think the problem we have is that there are several proprietary stream applications.
Is there such a thing as universal stream player?
Re: RA Visuals
No, but you could easily make a field to take a URL and then have an iframe to encapsulate the frame on the portal. I think
I know my web cam doesn't allow easy video streaming, but it does have an easy URL for a screenshot. I would use something like that.
What I setup on my own web page is to use that screenshot with some javascript to refresh every 2 seconds, so it seems like I have a live video feed It actually works quite well, except I haven't added the code to stop/start the video
Re: RA Visuals
I'm going to set it now, but the default 0 made a big frame pop up with a 404 error.
404 - File or directory not found.
The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.
Re: RA Visuals
Ok, added it, and it looks good. Anyway to make the height/width adjustable? I'm going to try some things on my end to make it fit better, but overall nice improvement
Re: RA Visuals
Cool, so I'm using my php wrapper on my static image link. I've set the size to fit the iframe and centered and all..
Very nice... Your slowly taking away my reasons for doing my own cool dashboard Actually, I still have reasons, but this is very cool. And if it had been there already, I may not have started this project of mine..
Re: RA Visuals
When I first tried to test... I refreshed the portal page, there was a big ugly frame with a 404 error in it. When I went to portal settings the default link for the webcam was set to 0.rimai wrote:what do you mean as default 0??
Re: RA Visuals
Weird... It should have been blank and not zero.
Let's wait for more users and see if anyone else complains.
Re: RA Visuals
To the portal? I can't see it...rimai wrote:I added the feature.
Would you like to test?
Re: RA Visuals
I guess this confirms that the zero is not there for himcosmith71 wrote:To the portal? I can't see it...
I'm not so sure how lnevo got to have a default zero in there
But, go to the portal settings and enter you webcam url
Re: RA Visuals
All I see under portal settings is Portal() function requires security key and send email notifications.
RA Visuals
I had to shift reload to see it... Try clearing your cache if that doesn't do it,
Re: RA Visuals
OK, what am I missing?
Re: RA Visuals
Yes. Using Chrome. IE won't even load the portal.
Re: RA Visuals
Got it. I had to check Send email notifications.
