I can access the WiFi server at IPaddress:2000/wifi and it will give me control to turn on and off the relays.
My problem is when I go to the portal it shows the following....
Reef Angel wifi address: 74.161.xxx.xxx:2000
My reefangelid: Sacohen
Connection Status: Unreachable Address
Last Update: 5/16/2013 11:08:19 PM
Displaying data from: Webbanner database
The only thing that I can think of and I'm not sure how to change it was when I went thru the wizard I did not add a Portal() security key, but I did turn it on in the Portal.
The thing is if I turn it off in the portal it doesn't make a difference. It is still unreachable.
Here is my code...
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port1,12,0,22,0 );
ReefAngel.StandardLights( Port2,13,0,21,0 );
ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.Relay.DelayedOn( Port5,10 );
ReefAngel.Portal( "Sacohen" );
