Are you sure you set the internal memory correctly?
What happens if you use the ControllerTester code?
File->Sketchbook->Example Codes
Portal/ android/ Apple app internal memory
Re: Portal/ android/ Apple app internal memory
i finally had a chance to do this. with the test code, port one (heater), does not work. Port three(fan), does work. interesting to note though, i had a light hooked up to port one while uploading the code, and port one came on for one second then shut off... I'm assuming that would be a bad relay correct? is that an easy fix? I can solder.
Yes, you can replace yourself.
http://forum.reefangel.com/viewtopic.php?f=2&t=1886
new development on this.... it is apparently a bad monitor cable. Accidentally moved it, while messing with stuff and port came on.. sorry for the goose chase.
It's there a special cable you have to use? I plugged in a standard monitor cable..brand new..and the relay stayed making a high pitched squeel
Sent from my SCH-I535 using Tapatalk 4 Beta
Svga will all 15 pins wired
