Portal Connection Status Unreachable Address
Related to the Portal
PostPosted: Fri May 31, 2013 5:11 pm
My portal page is showing Connection Status Unreachable Address.
The Wifi seems to be working because...
The TCP connection status is flashing green slow.
The TX/RX data transfer blinks yellow fast occasionally.
The Portal says Connection Status: Unreachable Address
I can ping the internal IP address. and when I go to http://www.yougetsignal.com/tools/open-ports/ it shows port 2000 is open, but the IP address is different then what the portal shows.
The portal shows 65.4.130.173.
My Router and yougetsignal.com shows XX.161.16.32
The WiFi does not seem to be sending the portal my correct IP address anymore.
PostPosted: Fri May 31, 2013 5:33 pm
Out debug output is probably interfering..
Finish the tests up we discussed and comment out the Serial.print commands
PostPosted: Fri May 31, 2013 5:49 pm
Trying to run it again now.
Return to Portal
