Portal not displaying relay activity and web chart info
Hi,
for some reason (possibly due to my own erroneous input) the relay activity and web charts contain no info.
I have also noticed that when the portal opens it initially shows a last update date of 5/12/2012 and then after the first refresh changes to today's date.
Can anyone advise what I may have done wrong?
cheers
cheers
- portal 1.jpg (56.92 KiB) Viewed 6377 times
- portal 2.jpg (58.74 KiB) Viewed 6377 times
Re: Portal not displaying relay activity and web chart info
It is most likely something in the code that is causing SendPortal not to run. Check if you turned on the portal key and it matches your code, otherwise can you post your ino.
I dont use a portal key
// Globals Needed for RF Mode on Custom Main
byte vtechmode; byte vtechspeed;
byte vtechpercent;
boolean bFeeding=false;
byte x = 6;
byte y = 2;
byte t;
char text[7];
//Custom Main, Graph & Menu
// ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawText(3,255,6,2," Reef of Low");
ReefAngel.LCD.DrawDate(7, 120);
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 123, "|");
vtechmode=ReefAngel.RF.Mode;
vtechspeed=ReefAngel.RF.Speed;
vtechpercent=ReefAngel.RF.Duration;
ReefAngel.LCD.Clear(255, 35, 20, 20, 85);
ReefAngel.LCD.DrawText(0,255,18,21,"EcoSmart Mode");
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,25,31,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,31,"Lagoonal");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,31,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,25,31,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,31,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,25,31,"STM_NTM.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,25,31,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,31,"Night");
ReefAngel.LCD.DrawText(2,255,32,42,"Speed");
ConvertNumToString(text, vtechspeed, 1);
if (vtechspeed )ReefAngel.LCD.DrawLargeText(0,255,35,51,text);
ReefAngel.LCD.DrawText(23,255,32,62,"Duration");
ConvertNumToString(text, vtechpercent, 1);
if (vtechpercent) ReefAngel.LCD.DrawLargeText(0,255,35,70,text);
ReefAngel.LCD.DrawText(0,255,10,80,"Tank");
ReefAngel.LCD.DrawLargeText(COLOR_RED, 255, 10, 88, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,100,80,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 85, 88, text, Num8x8);
ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
ReefAngel.FeedingModePorts = Port4Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 290 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
// ReefAngel.Relay.On( Port8 );
// if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port7); // Turn Skimmer off if Return is off and water level increases in sump
// ReefAngel.Relay.Set(Port7,ReefAngel.LowATO.IsActive()); // Turn Skimmer on if Return is on and water level in the sump is normal
ReefAngel.StandardHeater( Port1,251,261 );
ReefAngel.StandardHeater( Port2,251,261 );
// ReefAngel.StandardFan( Port3,271,281 );
// ReefAngel.StandardLights( Port3,20,0,5,0 );
// ReefAngel.StandardLights( Port6,20,0,0,0 );
ReefAngel.StandardLights( Port5,21,0,10,0 );
// ReefAngel.DosingPumpRepeat( Port8,0,180,30);
ReefAngel.CO2Control ( Port8,604,615 ); //was 635 - 645
ReefAngel.DosingPumpRepeat( Port3,0,180,120);
// ReefAngel.RF.SetMode(Constant,80,5);
// ReefAngel.RF.SetMode(Random2,50,5);
// ReefAngel.RF.SetMode(Smart_NTM,50,10);
// ReefAngel.RF.SetMode(Smart_NTM,60,8);
// ReefAngel.RF.SetMode(Custom,30,0); //Custom Mode Sync
// ReefAngel.RF.SetMode(Custom,50,1); //Custom Mode Anti-Sync
// ReefAngel.RF.SetMode(Custom,50,2); //Custome Mode Back of tank
/////// ATTEMPT TO CHANGE MODE @ TIMES
if ( ReefAngel.RF.Mode != Feeding_Start)
if (hour()==10)
ReefAngel.RF.SetMode(ReefCrest,30,20);
else if (hour()>=0 && hour()<1)
ReefAngel.RF.SetMode(Lagoon,80,15);
else if (hour()>=1 && hour()<2)
ReefAngel.RF.SetMode(Lagoon,60,20);
else if (hour()>=2 && hour()<3)
ReefAngel.RF.SetMode(Lagoon,50,25);
else if (hour()>=3 && hour()<4)
else if (hour()>=4 && hour()<5)
ReefAngel.RF.SetMode(Lagoon,70,10);
else if (hour()>=5 && hour()<6)
ReefAngel.RF.SetMode(Lagoon,60,15);
else if (hour()>=6 && hour()<7)
ReefAngel.RF.SetMode(Lagoon,50,20);
else if (hour()>=7 && hour()<8)
ReefAngel.RF.SetMode(Lagoon,40,30);
else if (hour()>=8 && hour()<9)
else if (hour()>=9 && hour()<10)
ReefAngel.RF.SetMode(Lagoon,60,10);
else if (hour()>=10 && hour()<11)
ReefAngel.RF.SetMode(Lagoon,80,5);
else if (hour()>=11 && hour()<12)
ReefAngel.RF.SetMode(Smart_NTM,90,6);
else if (hour()>=12 && hour()<13)
ReefAngel.RF.SetMode(Smart_NTM,80,10);
else if (hour()>=13 && hour()<14)
ReefAngel.RF.SetMode(Smart_NTM,70,12);
else if (hour()>=14 && hour()<15)
ReefAngel.RF.SetMode(Smart_NTM,60,10);
else if (hour()>=15 && hour()<16)
ReefAngel.RF.SetMode(Smart_NTM,40,8);
else if (hour()>=16 && hour()<17)
ReefAngel.RF.SetMode(Lagoon,50,10);
else if (hour()>=17 && hour()<18)
ReefAngel.RF.SetMode(Lagoon,80,10);
else if (hour()>=18 && hour()<19)
ReefAngel.RF.SetMode(Constant,60,10);
else if (hour()>=19 && hour()<20)
ReefAngel.RF.SetMode(Constant,50,10);
else if (hour()>=20 && hour()<21)
ReefAngel.RF.SetMode(Constant,40,10);
else if (hour()>=21 && hour()<22)
ReefAngel.RF.SetMode(Constant,45,10);
else if (hour()>=22 && hour()<23)
else if (hour()>=23 && hour()<0)
ReefAngel.RF.SetMode(Lagoon,50,15);
ReefAngel.RF.SetMode(ReefCrest,40,8);
if (hour()>=8 && hour()<10)
ReefAngel.PWM.SetDaylight( LongPulseMode(0,40,10,true) ); // Long pulse at 40% with 10s pulse on sync mode
else if (hour()>=10 && hour()<16)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(75,90,2000,true) ); // Nutrient Transport on sync mode
ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 75% + - 20 on sync mode
else if (hour()>=17 && hour()<20)
ReefAngel.PWM.SetDaylight( LongPulseMode(0,60,4,true) );
// ReefAngel.PWM.SetDaylight( NutrientTransportMode(75,90,2000,true) ); // Nutrient Transport on sync mode
else if (hour()>=20 && hour()<24)
ReefAngel.PWM.SetDaylight( TidalSwellMode(60,true) ); // Tidal Swell at 60% on sync mode
ReefAngel.Portal( "appleseed" );
Hmm only thing I can see is that you are using username appleseed but your forum name is Appleseed. Not sure if this is case-sensitivd.
Make sure that in the portal settings page the key is in fact disabled. Thats all I can see that could be causing it..
I changed my id to Appleseed (thanks to my awesome bluetooth adapter I didnt have to leave my workstation )
but it does not seem to have made any difference
The forum username in the portal is not case sensitive, so it wouldn't make a difference.
I'm thinking it is something in your wifi attachment.
What did you use to configure it?
Dave's wify utility or the one that came with the RA installer?
I configured it by hand :/ via the usb serial console using the set commands.
<2.35> get e
WiFly Ver 2.35, 06-12-2012 on RN-131
Beacon=100
Probe=5
Reboot=0
OPEN=
CLOSE=
REMOTE=
FlushSize=1024
MatchChar=0
FlushTimer=10
IdleTimer=0
CmdChar=$
IF=UP
DHCP=OFF
IP=172.16.254.200:2000
NM=255.255.255.0
GW=172.16.254.1
HOST=0.0.0.0:2000
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
DNS=194.168.4.100
Name=server1
Backup=backup2
FTP=208.109.14.133:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=reef_mon
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
Passphrase=1234567890
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x1
TimeEna=0
TIMEADR=129.6.15.28:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=WiFly-GSX
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Sensor=0x0
SensePwr=0x0
Beacon=100
Probe=5
Reboot=0
OPEN=
CLOSE=
REMOTE=
FlushSize=1024
MatchChar=0
FlushTimer=10
IdleTimer=0
CmdChar=$
IF=UP
DHCP=OFF
NM=255.255.255.0
GW=172.16.254.1
HOST=0.0.0.0:2000
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
DNS=194.168.4.100
Name=server1
Backup=backup2
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=reef_mon
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x1
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=WiFly-GSX
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Sensor=0x0
SensePwr=0x0
Host is not set properly
It needs to point to portal ip
I assume you mean;
HOST=0.0.0.0:2000
should it be 198.171.134.6:80
HOST=0.0.0.0:2000
I think I set it to the host 0.0.0.0 when I was having issues with the wifi module.. :/
Yes, but not sure what else might be missing. That was a big red flagAppleseed wrote:I assume you mean;
HOST=0.0.0.0:2000
I would also change the idletimer to 3
IdleTimer=0
IdleTimer=0
cool, set the idletimer to 3, will try again and see what happens.
one other stupid question, is it necessary to power off the head-unit when connecting/disconnecting the bluetooth and wifi modules? I usually do but was not sure if i should or should not.
Not for wifi, maybe for bt
I assume you mean they are hot swappable?.
rimai wrote:sorry... yeah..
I fixed it
It seems the relay and web banners still not being updated. The portal does show the correct ph, temps etc.
Unless im being to impaitent...
I can connect to my RA using the android app (via the mobile network), so i assume my nat etc is working.
Please check these settings against yours.
This is the macro file I use to program the units:
send '$$$'
wait 'CMD'
sendln 'set ftp address 198.175.253.161'
wait'AOK'
sendln 'save'
wait 'config'
sendln 'set wlan ssid testing'
wait 'AOK'
sendln 'set wlan pass a01b02c03d'
wait 'AOK'
sendln 'set option deviceid ReefAngelWifi'
wait 'AOK'
sendln 'set w j 1'
wait 'AOK'
sendln 'set c c 0'
wait 'AOK'
sendln 'set c r 0'
wait 'AOK'
sendln 'set c o 0'
wait 'AOK'
sendln 'set c i 3'
wait 'AOK'
sendln 'set dns name www.reefangel.com'
wait 'AOK'
sendln 'set i h 198.171.134.6'
wait 'AOK'
sendln 'set i r 80'
wait 'AOK'
sendln 'set i f 0x06'
wait 'AOK'
sendln 'set s t 0x10'
wait 'AOK'
sendln 'set u m 2'
wait 'AOK'
sendln 'set i p 2'
wait 'AOK'
sendln 'set u b 57600'
wait 'AOK'
sendln 'set s p 0'
wait 'AOK'
sendln 'set c s 1420'
wait 'AOK'
Ill reconfigure it using the relevant parameters.
I did try use the Wifi Attachment Setup Utility to reconfigure it but kept getting the error "Please disconnect and then reconnect the Reef Angel Wifi Attachment from the USB-TTL cable and try again" which reminded my why i manually configured the module :/
Whoo hoo, i reconfigured it using that script but with a static IP and it seems to be working
thanks again for all your help.
It now beer time
It now beer time
