Hi
I cant read from portal after I updated my RA to the newest version
I checked my router and found this
Use DynDNS: Yes
Internet Service: Internet
Username: coolsilver
Password: ********
IP address: 94.98.xxx.xxx
Dynamic DNS service: dyndns
Hostname: 198.171.134.6:80 (Update error)
on reef angel portal
Reef Angel wifi address: 94.98.xxx.xxx:2000
My reefangelid: coolsilver
Connection Status: Unreachable Address
Last Update: 09 July 2013 09:39:59
Displaying data from: Webbanner database
it was uploading before the update and it was connected
can any one help please
( Unreachable Address )portal issue
Re: ( Unreachable Address )portal issue
The reefangel server does not implement dynamic dns service.
You need to use your own DDNS service, such as no-ip.com or any other one.
problem solved after reprogram the WIFI using WIFI utility ( also I found WIFI update )
