Relay activity not coming up.
Related to the Portal
Is anyone else have a problem with the relay activity not coming up?
This started happening about 2-3 days ago.
I'll click on Relay Activity and it will never com up.
I've even walked away for like 10 min and come back and it is still the spinning wheel of death.
I thought it might be because my streaming camera was eating up all the bandwidth, but I took it out of the portal and it is still happening.
Re: Relay activity not coming up.
I'll check on it later
Thanks.
It will come up once in a while, but for the most part it just gives me the spinning wheel.
I increased the timeout.
Can you check?
It came up this time. I will keep an eye on it and let you know if it happens again or if it's OK.
Thanks Roberto.
That seems to have done it. It's come up every time I've asked for it ever sine you changed the timeout setting.
Thanks again.
Cool.
Thanks for informing that it was failing :)
No Problem.
Roberto this started happening again.
The Relay activity is not coming up.
It just spins and spins.
