Remote PWM
Related to the Portal
PostPosted: Fri Jul 26, 2013 10:57 am
Is there a way to remotely set the current PWM channel levels?
PostPosted: Fri Jul 26, 2013 1:08 pm
Are you talking about the current for Jebao Pumps like the WP-25 or 40?
The answer is yes. You would need to set you code for the pumps to use the internal memory and then you can adjust setting in the web portal under Internal Memory>DC Pump (Jebao/Tunze)
PostPosted: Fri Jul 26, 2013 3:22 pm
Sorry I should have been more clear. I had spotty Internet where I was. I have four Rapid LED drivers controlled via PWM. I want to be able to turn down the level remotely. The currently run on the parabola setting.
PostPosted: Fri Jul 26, 2013 5:45 pm
I'm not 100% sure of that, but I think you can. I'm sure someone else with more knowledge on this will chime in.
PostPosted: Fri Jul 26, 2013 10:06 pm
Yes, you can do that.
If you choose the path of using internal memory when using the wizard, you can use the portal to change the % of each channel for both start and end whenever you want to :)
PostPosted: Mon Jul 29, 2013 3:29 am
Is there any functional difference between using the memory vs calling the function in code?
Return to Portal
