Remote PWM
Posted: Fri Jul 26, 2013 10:57 am
by ufgators2k
Is there a way to remotely set the current PWM channel levels?
Re: Remote PWM
Posted: Fri Jul 26, 2013 1:08 pm
by Sacohen
Are you talking about the current for Jebao Pumps like the WP-25 or 40?
The answer is yes. You would need to set you code for the pumps to use the internal memory and then you can adjust setting in the web portal under Internal Memory>DC Pump (Jebao/Tunze)
Re: Remote PWM
Posted: Fri Jul 26, 2013 3:22 pm
by ufgators2k
Sorry I should have been more clear. I had spotty Internet where I was. I have four Rapid LED drivers controlled via PWM. I want to be able to turn down the level remotely. The currently run on the parabola setting.
Re: Remote PWM
Posted: Fri Jul 26, 2013 5:45 pm
by Sacohen
I'm not 100% sure of that, but I think you can. I'm sure someone else with more knowledge on this will chime in.
Re: Remote PWM
Posted: Fri Jul 26, 2013 10:06 pm
Yes, you can do that.
If you choose the path of using internal memory when using the wizard, you can use the portal to change the % of each channel for both start and end whenever you want to
Re: Remote PWM
Posted: Mon Jul 29, 2013 3:29 am
by ufgators2k
Is there any functional difference between using the memory vs calling the function in code?
