Dimming Expansion Tab
From the Internal Memory Drop down the dimming expansion tab is only displaying 4 out of the six channels so I cant make adjustments to the last two channels, but from the dashboard I can see all of them and their % power. How can I correct this issue?
Re: Dimming Expansion Tab
I have the same issue did you ever get this sorted?
You can write to the memory locations directly. I don't have the files in front of me, but you can find all the definitions in Globals\Globals.h
The syntax is
http://reefangelwifi:2000/mbXXX,YYY
Where xxx is the memory location and yyy is the value.
Replace mb with mi if the value is an integer (Mem_I_something)
Replace reefangelwifi with your ip if the dns does not work.
You can leave off ,YYY to query the current setting
The syntax is
Did you try a different browser or decreasing the font size?
Sent from my SPH-L710 using Tapatalk 4
Yes just tried Firefox, Internet explorer and Safari. Firefox and IE both get 4 channels two show (regardless of font size) and Safari on my Iphone gets 3.
lnevo-
I am totally new to this, is there any way you can explain a little more on writing to the memory location?
I've only seen 4 max...rimai wrote:Did you try a different browser or decreasing the font size?
Won't be able to for a bit...maybe someone else can explain it before i get home..fckgravity wrote:lnevo-
When the apps send commands to the controller to update/write the values to the internal memory locations, there is a certain structure that needs to be followed: (see this link for more info on all the commands: http://forum.reefangel.com/viewtopic.php?f=7&t=1541)
Like was stated earlier, when writing the values, you must specify the memory location and it's size (either byte or integer). An example would be to change the standard lights ON hour:
This command changes the ON HOUR for the Standard Lights function to 8am. The location is 204 and it is a BYTE sized location.
Byte locations only take up 1 memory space.
Integer locations take up 2 memory spaces.
The amount of space it takes up determines the value that can be stored. Byte locations can store a value from 0-255 and integer locations can store a value from 0-32767. As you can see, Integers can store larger numbers.
The memory locations are based on their functions. There's no reason to take 2 memory spaces (Integer size) to store the value for the Standard Lights ON Hour because that value can only be from 0-23. If we used 2 spaces, there would be wasted space/memory.
Yes, it does get a little confusing, however the memory locations are clearly labeled in the Globals.h file. There's an I in the name for Integer (meaning 2 spaces) and a B in the name for Byte. Also, my Java Status App has the memory locations referenced in it as well as my Android app.
Now, back to the commands...
All the applications use the same URL formatted string to update/write the memory locations. I previously showed how to set a BYTE variable. It was:
To set an INTEGER variable, such as the Wavemaker 1 Timer, you would do this:
As you can see, the INTEGER command is an /mi and the BYTE command is an /mb.
Hopefully that helps out a little more with writing memory locations.
http://YOURIP:2000/mb204,8
http://YOURIP:2000/mi208,500
I fixed the width of the Portal.
When I added the DC Pump section, it became too small to fit everything.
Thanks for the help everyone, its all good now.
