I have the Power Control Expansion connected and working, but it is not showing up under the relay activity on the portal.
There is a brief period around 9pm last night where it does show the ports, but nothing is ever plotted.
Power Control Expansion Not Show on Portal.
Re: Power Control Expansion Not Show on Portal.
I think you need at least one port on to show up.
Well it was on at 9Pm last night so shouldn't that be enough to at least plot an flat line for the rest of the day, Like Port 8 does now.
Port 8 used to be the ATO pump and as you can see it has been flat since at least 7pm yesterday.
I'm sure the ATO has kicked in at least once today, but it may not have been long enough for the portal to register it.
I'm going to try to hook up my moonlights tonight when I get home so that will definitely be on from 10pm to Noon.
