ph and temp graph
ph and temp graph
how can i see a graph log on ph and temp on the portal?
Re: ph and temp graph
It does that by default if you are sending data to the portal.
Log in to the Portal and click on web chart
Stupid Question perhaps.. But what does the very bottom plotting show?
On Mine, I see PH and TEMP
Then there's another graph on the bottom (light Blue) with no Legend.
Its the ph. The scale is set for both so ph is 1/10 of temp..
The blue bar is to move the range of time. You can move it to change the range of the timeline
