Hello,
I was just looking at the relay activity charts on the portal and noticed that my dosing pumps are turning on and off for different amounts of time. One time they will turn on for 5 minutes and the next time they will turn on for 10 minutes. I have them set for 12 minutes 5 times a day with a 20 minute offset. Here's my current code. Not sure if I'm looking at the info wrong or coded something wrong?
InternalMemory.LCDID_write(0);
ReefAngel.FeedingModePortsE[0] = Port1Bit;
ReefAngel.WaterChangePortsE[0] = Port2Bit | Port3Bit | Port4Bit | Port8Bit;
ReefAngel.Relay.On( Port3 ); //*Actinic
ReefAngel.Relay.On( Port4 ); //*Daylight
ReefAngel.Relay.On( Port5 ); //*Bio pellet reactor
ReefAngel.Relay.On( Box1_Port1 ); //*skimmer
ReefAngel.Relay.On( Box1_Port2 ); //*return pump
ReefAngel.Relay.On( Box1_Port3 ); //*cir pump
ReefAngel.Relay.On( Box1_Port4 ); //*cir pump
ReefAngel.Relay.On( Box1_Port7 ); //*water level controller
ReefAngel.Relay.On( Box1_Port8 ); //*top fuge pump
ReefAngel.StandardLights( Port1,22,30,13,30 ); //*sump fuge light
ReefAngel.StandardLights( Port2,13,30,22,30 ); //*top fuge light
ReefAngel.DosingPumpRepeat( Box1_Port5,0,288,720 ); //*Alk pump
ReefAngel.DosingPumpRepeat( Box1_Port6,20,288,720 ); //*Cal pump
ReefAngel.StandardATO( Port6,6000 ); //*Fresh water solenoid
ReefAngel.StandardHeater( Port7,775,785 );
ReefAngel.StandardLights( Port8,13,30,22,30 ); //*Light fan
ReefAngel.PWM.SetDaylight( PWMSlope(13,30,22,30,0,55,30,0) );
ReefAngel.PWM.SetActinic( PWMSlope(13,30,22,30,0,60,30,0) );
ReefAngel.Portal("elevatorguy1","****");
byte x;
byte y = 2;
char text[7];
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 30, 2, "Gonzo's Reef"); // Put a banner at the top
ReefAngel.LCD.DrawDate(6, 119); // Put the date and time at the bottom
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 132, 11); // Draw a black line under the banner
x = 12;
y += MENU_START_ROW+1; // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Tank Temp pH");
ConvertNumToString(text, ReefAngel.Params.PH, 100); // Get pH reading and convert
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text, Font8x16); // Put pH on the screen
ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10); // Get T1 temp and convert
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.DrawHugeNumbers(COLOR_WHITE, COLOR_BLACK, x, y, text); // Draw the temperature, white numbers on a colored background
x += (16*4) + 8;
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,8,y+25,"White %");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, 24, y+35, 1); // Draw the white light %
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+8,y+25,"Blue %");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+24, y+35, 1); // Draw the blue light %
// Code for drawing the relay box
ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 107, TempRelay);
Relay activity
Relay activity
They aren't...the ra only sends data to the portal every 5 minutes so it just looks that way.
Re: Relay activity
Thanks Inevo! I should have realized that reading though the forum but I didn't make the connection.
Re: Relay activity
There's a post and I have it in my code that logs the amount of seconds the relay is on and sends it to one of the portal custom variables. There's a thread too where I helped kirkwood I believe log this as well. So you have a few examples if you NEED to see how long the dosers are in fact running..
