Hi,
My Relay 2 (ATO PUMP) is not showing up in the portal's relay activity screen. Any ideas why this may be?
I tested it by engaging it but it doesn't show up. Other relays are showing up fine.
Relay 2 (ATO PUMP) not reflected in relay activity
Re: Relay 2 (ATO PUMP) not reflected in relay activity
The controller only sends data every 5 minutes
So if the ATO isn't 'ON" during the period the controller sends the data, it's not recorded?rimai wrote:The controller only sends data every 5 minutes
