Is the Multi-Channel Water Level sensor hooked into Portal yet? I'm seeing port 0 in there now but not sure if I should also be seeing 1-4 as well.
~Charlie
Multi-Channel Water Level in Portal?
Re: Multi-Channel Water Level in Portal?
Thanks, Roberto. Just wanted to make sure it wasn't something I had (or didn't have) in my code.
You can try the new web ui to check the values.
http://ipaddress:2000/wifi
I'll check it tonight. Can't get to it from my work network. I actually added the levels to my custom vars so I can still see them from the portal
