connection status: unreachable address
Related to the Portal
lurch
Re: connection status: unreachable address
Post by lurch »
Thank you its working. sorry it took me so many times to figure it out I'm really thankfull for you help
Yay :)
lurch
Post by lurch »
not working again. very disappointed in my purchase
lurch
Post by lurch »
Is there a way to know if my wifi adapter is still sending signal? Now when I try to set up port forwarding my computer does not show the reef angel. The blue light is still blinking but my phone app does not work either
Blue light means no connection. You want green light. Try to use the wifi setup again.
lurch
Post by lurch »
sorry I'm very frustrated it is a green light not blue.
You need to get intimate with your router. Most likely your router gave it a different ip address. You need to find on your router how to "reserve" the ip address so it doesn't change. The problem if it changes is 1) you don't know what it changed to and 2) it could mess up your port forwarding.
I know its frustrating, this part takes really learning a bit of networking. This process is no different than with any other controller and I've seen plenty of threads for the same issues with apex too.
We'll help you get it figured out, try not to let the technical issues get you worked up.
lurch
Post by lurch »
I think your right I think I need a reserve ip address so next to call internet provider thank you.
