connection status: unreachable address
Re: connection status: unreachable address
No. The external ip address is your routers ip on the internet side.
The next step would be on your router to make sure forwarding is setup to forward to the IP of your wifi module.
If you point your phone to the ip of your wifi module does it work when your on your wifi network?
Yes the phone app works on wifi to do like feeding mode but not on mobile internet
Right. Your forwarding isn't good. Search for your router and how to setup port forwarding on google..
that i s where I'm stuck I've been looking at the online tutorials and I've got it to where the IP address works for port forwarding but I still can't get it to work for PortalI'm trying to put in my computer's IP address and I tried putting in the Wifi ipI can't seem to get the port forwarding to work on anything but the computer's IP address
You dont put either ...you put the external ip. Whatever you get when you try whatsmyip.org
Do you happen to have 2 routers? One for the internet and one for wifi?
Yes I do. Our modem went down and when we bought a new one it had wifi also so I have 2 wifi options in my house
You'll need to setup the forwarding on both then. THe first one forwards to the second and the second forwards to the wifi module. A bit tricky
I think I need to remove one and see if that helps
removed extra wifi and set up port forwarding on router. the port forwarding test web sight shows port 2000 is open but when I go to portal it still says "connection status: unreachable address"
when doing the port forwarding test should I be using current ip address or the wifi adapter address?
Your controller has never sent data to the server.
Make sure you are not using a security key in the Portal. If you are, make sure you edit your code to match the same key you entered in the portal.
If enabled, please make sure to change the Portal() function in your INO code. It should follow this format:
ReefAngel.Portal("username","key");
do I do this on the portal site or on the controller
If you enable the security key in the portal, you must also change your code to match the same key you entered in the portal.
If you disable it in the portal, then you don't need to change anything in the code.
The ip on the portal needs to be your external ip. Not the wifi module, not the computer. Its your internet provider ip on the closest router to the internet. http://whatsmyip.org
so on the reef angel web site I can adjust the portal settings
still no luck made changes in portal still not working
Ok, I don't think you understood what I said.
If you enable the security key in the portal, you MUST change your code to match the same key you have entered in the portal settings.
Where mykey is the same thing you set in the portal settings.
If the keys don't match, the server rejects your data and it never saves it.
If your code is like this:
And you set a portal key, you will never get it to work. You should disable the portal key to make it work or change it to match the portal key like the code posted above.
So, you MUST change your code to be like this:If enabled, please make sure to change the Portal() function in your INO code. It should follow this format:
ReefAngel.Portal("lurch","mykey");
ReefAngel.Portal("lurch");
turned off password but still cant use portal
Thank you its working. sorry it took me so many times to figure it out I'm really thankfull for you help
not working again. very disappointed in my purchase
Is there a way to know if my wifi adapter is still sending signal? Now when I try to set up port forwarding my computer does not show the reef angel. The blue light is still blinking but my phone app does not work either
Blue light means no connection. You want green light. Try to use the wifi setup again.
sorry I'm very frustrated it is a green light not blue.
You need to get intimate with your router. Most likely your router gave it a different ip address. You need to find on your router how to "reserve" the ip address so it doesn't change. The problem if it changes is 1) you don't know what it changed to and 2) it could mess up your port forwarding.
I know its frustrating, this part takes really learning a bit of networking. This process is no different than with any other controller and I've seen plenty of threads for the same issues with apex too.
We'll help you get it figured out, try not to let the technical issues get you worked up.
I think your right I think I need a reserve ip address so next to call internet provider thank you.
