Portal webcam URL
Related to the Portal
PostPosted: Sat Dec 14, 2013 4:54 pm
I don't yet have a webcam for my setup but will be getting one soon. To test how it would work I added a live feed URL to the portal settings, and that is where it all went wrong :oops:
Now when I open the portal it loads the feed and then goes straight to the website URL that I entered in the settings. There appears to be no way of stopping this so that I can delete the URL.
Is there a way can I remove the URL from my portal configuration, or can this only be done by the administrator?
Own goal, sorry!
PostPosted: Sat Dec 14, 2013 6:28 pm
You can try opening portal settings before it loads or try turning off your webcam too...then you should be able to change it.
PostPosted: Sat Dec 14, 2013 7:13 pm
It loads and displays too quick to click on settings, I have been trying that all afternoon LOL.
PostPosted: Sat Dec 14, 2013 7:53 pm
Turn off your webcam. Then it should fail to load
PostPosted: Sat Dec 14, 2013 8:04 pm
That is the problem, I dont have a webcam. I entred the URL for a live feed from a website showing a live reef. As soon as the portal page opens the web page jumps to that site. There is no time to scroll down and click on the portal settings!
PostPosted: Sat Dec 14, 2013 8:10 pm
Whats the name of the site? Put an entry into your hosts file for the site with a bogus ip address.
PostPosted: Sat Dec 14, 2013 8:17 pm
Oh wow :(
I can't change it either... I just shoots me to the other website. :evil:
I will have to log directly into the database and force a change through sql statement.
PostPosted: Sun Dec 15, 2013 5:40 am
I am so sorry Roberto :oops:
Just wanted to see where on the portal page the feed would be positioned. I have embedded video feeds in webpages before such as Youtube streams, I can only think that this feed has a anti hijack code built in so that it cannot be used on other sites. If I am stupid enough to do this again I will take a close look at the code behind the URL first.
Thank you for removing the link and restoring the portal to me. I use it so much that it has become my main RA tool since Johns iPad app died.
PostPosted: Sun Dec 14, 2014 4:51 pm
What is the fix for this? I tried using Ustream broadcast, and now can't get to portal.
PostPosted: Sun Dec 14, 2014 9:27 pm
Yeah, I'll fix it for you tomorrow.
Next
Return to Portal
