Web chart is blanck
Web chart is blanck
When I look on the web chart it is blank why?
Jan
Jan
Re: Web chart is blanck
Your controller never sent data to the Portal.
Do you have the wifi attachment configured correctly?
Hmm I think it is
I can see temp ph etc.
Is ther a guide on the to used when setting up wifi ?
I have just loaded standard code
dont know how to read code loaded in the reefangel
The standard code doesn't send data to the portal.
You will need to generate one with the wizard.
is it on the download page ?
thanks i found it
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
InternalMemory.OverheatTemp_write( 320 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,9,0,23,0 );
ReefAngel.StandardLights( Port2,11,0,22,30 );
ReefAngel.StandardLights( Port3,11,0,23,0 );
ReefAngel.StandardLights( Port4,11,0,23,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(11,0,23,0,15,100,15) );
ReefAngel.PWM.SetActinic( PWMParabola(11,0,23,0,15,100,15) );
ReefAngel.Portal( "jhp" );
How often is the data send to the server it is still blank
the dash board is ok
Still not working
you can see if I send data
No, I don't see any data.
Can you send me the dump from the "get e" command?
You will need to use tera term or putty to access the command mode on the module.
Check the manual for instructions.
ok I will do it the next days
Hi Roberto,
I think i have the same issue.
my web banner is also blank, here's my wifi info, thanks.
<4.00> get e
wifly-GSX Ver 4.00, Mar 27 2013 13:52:34 on 131C11
Beacon=102
Reboot=0
IF=UP
DHCP=OFF
IP=172.16.1.39:2000
NM=255.255.0.0
GW=172.16.0.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1524
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=0.0.0.0
Name=name.no-ip.biz
Backup=rn.microchip.com
Lease=86400
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=XXXXXX
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=xxxxxxxxxx
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>
<4.00> get e
Beacon=102
Reboot=0
IF=UP
DHCP=OFF
IP=172.16.1.39:2000
NM=255.255.0.0
GW=172.16.0.1
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1524
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=0.0.0.0
Name=name.no-ip.biz
Lease=86400
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=XXXXXX
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>
Hi Roberto,
I have change the dns name to http://www.reefangel.com but that did not help.
looks like i am sending data.
<RA><ID>acabano</ID><T1>800</T1><T2>1211</T2><T3>800</T3><PH>754</PH><R>18</R><RON>64</RON><ROFF>223</ROFF><ATOLOW>0</ATOLOW><ATOHIGH>0</ATOHIGH><EM>0</EM><REM>0</REM><PWMA>70</PWMA><PWMD>70</PWMD></RA>
<4.00> get e
Beacon=102
Reboot=0
IF=UP
DHCP=OFF
IP=172.16.1.39:2000
NM=255.255.0.0
GW=172.16.0.1
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1524
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=0.0.0.0
Name=www.reefangel.com
Lease=86400
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=xxxxxxxx
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>
<4.00> get e
Beacon=102
Reboot=0
IF=UP
DHCP=OFF
IP=172.16.1.39:2000
NM=255.255.0.0
GW=172.16.0.1
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1524
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=0.0.0.0
Lease=86400
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=xxxxxxxx
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>
You are setting the ip manually, right?
These are the differences I noticed:
FLAGS=0x6
DNS is not setup. It must be setup. Ask your ISP which DNS server they use.
I think when you set the DNS, you should be able to connect.
FLAGS=0x6
Yes, ip is static. i have found the primary dns on my router "u verse" 3801HGV
<4.00> get e
Beacon=102
Reboot=0
IF=UP
DHCP=OFF
IP=172.16.1.39:2000
NM=255.255.0.0
GW=172.16.0.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1524
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=x8.9x.1x6.x
Lease=86400
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=xxxxxx
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>
<4.00> get e
Beacon=102
Reboot=0
IF=UP
DHCP=OFF
IP=172.16.1.39:2000
NM=255.255.0.0
GW=172.16.0.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1524
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=x8.9x.1x6.x
Lease=86400
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=xxxxxx
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>
I kind of feel that you are using the wrong ip address.
Are you able to connect to your controller?
Did you try letting the wifi attachment just get the ip from DHCP?
I was able to control/see update on my iPhone 5s, but the graph does not work, same with portal web chart.
I can ping my controller, port 2000 is open. I'm not sure the DNS ip i have tried both the dns ip from my router GUI
Thanks for looking.
Thanks for looking.
Hey Roberto,
Thanks a bunch, once DHCP is enabled web chart works.
