Yes, ip is static. i have found the primary dns on my router "u verse" 3801HGV
<4.00> get e
wifly-GSX Ver 4.00, Mar 27 2013 13:52:34 on 131C11
Beacon=102
Reboot=0
IF=UP
DHCP=OFF
IP=172.16.1.39:2000
NM=255.255.0.0
GW=172.16.0.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1524
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=x8.9x.1x6.x
Name=www.reefangel.com
Backup=rn.microchip.com
Lease=86400
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=xxxxxx
Chan=0
ExtAnt=0
Join=1
Auth=WPA2
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=xxxxxxxxxx
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>
Web chart is blanck
Re: Web chart is blanck
I kind of feel that you are using the wrong ip address.
Are you able to connect to your controller?
Did you try letting the wifi attachment just get the ip from DHCP?
I was able to control/see update on my iPhone 5s, but the graph does not work, same with portal web chart.
I can ping my controller, port 2000 is open. I'm not sure the DNS ip i have tried both the dns ip from my router GUI
Thanks for looking.
Thanks for looking.
Hey Roberto,
Thanks a bunch, once DHCP is enabled web chart works.
