Connection Status:Unreachable Address & WiFi problems
Related to the Portal
PostPosted: Mon Dec 16, 2013 10:04 am
I'm still struggling to get my web portal to work :oops:
Upgraded to the plus board but now the LCD does not work, looks like the LCD screen is not compatable with the new Plus board?
Here is my new Code for the Plus Board (Don't know if there is a fault in my code maybe?)
ReefAngel.Init();
InternalMemory.OverheatTemp_write( 260 );
InternalMemory.HeaterTempOn_write( 250 );
InternalMemory.HeaterTempOff_write( 255 );
InternalMemory.ChillerTempOn_write( 260 );
InternalMemory.ChillerTempOff_write( 255 );
InternalMemory.ATOExtendedTimeout_write( 100 );
InternalMemory.ATOHourInterval_write( 0 );
InternalMemory.WaterLevelLow_write( 10 );
InternalMemory.WaterLevelHigh_write( 15 );
InternalMemory.DP1RepeatInterval_write( 30 );
InternalMemory.DP1Timer_write( 30 );
InternalMemory.DP2RepeatInterval_write( 30 );
InternalMemory.DP2Timer_write( 120 );
InternalMemory.DelayedStart_write( 4 );
InternalMemory.PWMSlopeStartD_write( 0 );
InternalMemory.PWMSlopeEndD_write( 45 );
InternalMemory.PWMSlopeStartA_write( 5 );
InternalMemory.PWMSlopeEndA_write( 60 );
InternalMemory.PWMSlopeStart0_write( 0 );
InternalMemory.PWMSlopeEnd0_write( 45 );
InternalMemory.PWMSlopeStart1_write( 5 );
InternalMemory.PWMSlopeEnd1_write( 60 );
InternalMemory.PWMSlopeStart2_write( 10 );
InternalMemory.PWMSlopeEnd2_write( 45 );
InternalMemory.PWMSlopeStart3_write( 0 );
InternalMemory.PWMSlopeEnd3_write( 40 );
InternalMemory.IMCheck_write(0xCF06A31E);
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+20, MENU_START_ROW*3, "Memory Updated");
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*6, "You can now");
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+25, MENU_START_ROW*7, "upload your");
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL+33, MENU_START_ROW*8, "INO code");
wdt_reset();
I used this site, as mentioned in another thread: http://www.canyouseeme.org/
and its working
Success: I can see your service on 41.151.xxx.xxx on port (2000)
Your ISP is not blocking port 2000
Registered on no-ip.com
http://xxxxx.no-ip.org:2000/
and its working
Got a ZyXEL NBG4115 router
Port forwarding is setup and Dynamic DNS
I can access my RA through home and away function via the android App and the Reef Angle PC Client. But my web port gives Connection Status:Unreachable Address :!:
Any suggestions? What can possible be wrong???
PostPosted: Mon Dec 16, 2013 10:12 am
This code is just internal memory code.
It doesn't do anything for your controller.
I recommend you generate another code with the wizard and choose hard coded settings to make it easy.
As far as your screen, you probably have a gen1 screen and the RA+ board is setup for gen3 screen.
viewtopic.php?f=2&t=3111
So, to set it up for gen1 screens, you need this in your code:
  InternalMemory.LCDID_write(255);
Place it right above ReefAngel.Init();
PostPosted: Mon Dec 16, 2013 10:15 am
When you generate the new code, make sure you have this in there:
ReefAngel.Portal("Express%20Reef");
This is what is going to enable the portal. The wizard is supposed to place it in there for you though.
PostPosted: Mon Dec 16, 2013 10:23 am
Thank you Roberto, Now the screen is working :-) Happy days!!!
This is my code now...
byte buzzer=0;
byte overheatflag=0;
byte atoflag=0;
ReefAngel.WaterChangePorts = Port1Bit | Port6Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.SingleATO( true,Port1,100,0 );
ReefAngel.StandardHeater( Port2,250,255 );
ReefAngel.StandardFan( Port3,255,260 );
ReefAngel.DosingPumpRepeat( Port4,0,30,30 );
ReefAngel.Relay.DelayedOn( Port6,4 );
ReefAngel.DosingPumpRepeat( Port8,0,30,120 );
ReefAngel.PWM.SetDaylight( PWMParabola(7,0,20,0,0,45,0) );
ReefAngel.PWM.SetActinic( PWMParabola(6,0,21,0,5,60,5) );
ReefAngel.PWM.SetChannel( 0, PWMParabola(7,0,21,0,0,45,0) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(6,0,21,0,5,60,5) );
ReefAngel.PWM.SetChannel( 2, PWMParabola(7,0,20,0,10,45,10) );
ReefAngel.PWM.SetChannel( 3, PWMParabola(7,0,20,0,0,40,0) );
overheatflag = InternalMemory.read( Overheat_Exceed_Flag );
atoflag = InternalMemory.read( ATO_Exceed_Flag );
buzzer = overheatflag + atoflag;
if ( buzzer >= 1 ) buzzer = 100;
ReefAngel.PWM.SetChannel( 4, buzzer );
ReefAngel.Portal( "Express Reef" );
But the web portal is still not working, but I see it says : Last Update:Monday, December 16, 2013 11:19:56 AM
So something tells me there is something wrong, but nothing majors???
PostPosted: Mon Dec 16, 2013 10:24 am
Roberto where must I add this?
PostPosted: Mon Dec 16, 2013 10:32 am
Ok changed ReefAngel.Portal( "Express Reef" ); to ReefAngel.Portal("Express%20Reef");
but it is still not working?
PostPosted: Mon Dec 16, 2013 11:27 am
I can see updates.
Is it working now?
PostPosted: Mon Dec 16, 2013 11:34 am
It updated
My reefangelid:
Express Reef
Connection Status:
Unreachable Address
Last Update:
Monday, December 16, 2013 8:06:34 PM
Displaying data from:
Webbanner database
but it is not working still says Unreachable Address
PostPosted: Mon Dec 16, 2013 11:58 am
That is the port forwarding part.
PostPosted: Mon Dec 16, 2013 1:50 pm
@rimai, still not get it to work, last update was Monday, December 16, 2013 10:01:50 PM still get "Unreachable Address" :-(
Next
Return to Portal
