Connection Status:Unreachable Address & WiFi problems
Re: Connection Status:Unreachable Address & WiFi problems
Are you a member of that forum? Thats where the pictures are from...
- Express Reef
"If you can't ping your module than the ip may have changed...is your module blinking green or blue. Blue is not good."
Blinking Green
Blinking Green
- Express Reef
my ip dont change expressreef.no-ip.org
That is your EXTERNAL ip address that is used by no-ip.org... your wifi module has it's own IP address that is assigned by your router. That may have changed. The fact that the module is green indicates that it is on your network properly.
- Express Reef
"That is your EXTERNAL ip address that is used by no-ip.org... your wifi module has it's own IP address that is assigned by your router. That may have changed. The fact that the module is green indicates that it is on your network properly."
My WiFi module IP 10.0.0.33 did not changed...
Can you still ping and point your phone to that IP? If you can then either your router lost the forwarding OR the no-ip is not updating properly and your external IP address changed.
Hey dude,
I just started having the same issue. As Inevo said i reckon its the port forwarding. When you setup the wifi attachment it does the upnp forwarding for you. On a reboot it lost that and gave exactly your issue. I manually entered the details and rebooted and all is good now, give it a bash and if you haven't come right PM me on SaltyReef
