Reef Angel wifi address is wrong
On the portal page it shows my Reef Angel wifi address but the address wrong that's not the address of my wifi unit how do I change it in portal?
Re: Reef Angel wifi address is wrong
Its ok. Its your external ip address which is what the portal needs. If it's not working its because your port forwarding is not working.
It updates automatically as the server receives data from your controller.
According to the server, the last time it received data was 12/19.
You can see it in the banner:
http://forum.reefangel.com/status/banne ... lurch&t=-8
I think it is because you setup a portal key in the settings page and did not update the controller to use the same key.
I'd suggest you either disable the key or recode your controller to match the same key.
How do I recode the controller
So I set up port forwarding had it working. I checked it with "port forwarding tester" it worked woohoo . Now about an hour later the port is closed anyone else have this problem?
If you go to portal settings where you entered the key, you can read how to change, but here it is anyway:
If enabled, please make sure to change the Portal() function in your INO code. It should follow this format:
ReefAngel.Portal("username","key");
I think it the port forwarding that is my problem because that is how I have the user name and password set up on my controller
ReefAngel.Portal( "lurch","*********"); well this is how mine is set up did I do it wrong. I cant even use the phone app.
So I checked on my router devices connected to your Local Area Network (LAN) with the connection type. and it shows the reef angel inactive. Why would this be? Everything else using that uses the wifi show active even when not in use?
So this is my code
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.FeedingModePorts = Port5Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port5Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port5Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,14,0,21,0 );
ReefAngel.StandardHeater( Port2,751,761 );
ReefAngel.StandardLights( Port3,13,0,22,0 );
ReefAngel.Wavemaker( Port5,60 );
ReefAngel.PWM.SetDaylight( PWMParabola(9,0,20,0,0,100,0) );
ReefAngel.PWM.SetActinic( PWMParabola(9,0,20,0,15,100,15) );
ReefAngel.Portal( "lurch","v@#$%^&*a");
So I checked on my router devices connected to your Local Area Network (LAN) with the connection type. and it shows the reef angel inactive. Why would this be? Everything else using that uses the wifi show active even when not in use? Is it normal for the reef angel wifi to show inactive. The port forwarding works when the unit is showing active but not when in active could there be something wrong with the wifi unit I received?
I'm kinda confused if I remove my internet password everything works. I looked at my code and I'm sure I have the password in their correct I guess I'll try to convince the wife we don't need a password fingers crossed.
Have you configured a static IP address for your Wifi attachment via your routers DHCP settings?
You could also try setting a portal password using just letters and numbers. Maybe there is an issue with using one of the special characters that you are using? Worth a shot to rule that out?
