Reef Angel wifi address is wrong
Related to the Portal
lurch
Re: Reef Angel wifi address is wrong
Post by lurch »
So I checked on my router devices connected to your Local Area Network (LAN) with the connection type. and it shows the reef angel inactive. Why would this be? Everything else using that uses the wifi show active even when not in use? Is it normal for the reef angel wifi to show inactive. The port forwarding works when the unit is showing active but not when in active could there be something wrong with the wifi unit I received?
lurch
Post by lurch »
I'm kinda confused if I remove my internet password everything works. I looked at my code and I'm sure I have the password in their correct I guess I'll try to convince the wife we don't need a password fingers crossed.
ReEfnWrX
Post by ReEfnWrX »
Have you configured a static IP address for your Wifi attachment via your routers DHCP settings?
ReEfnWrX
Post by ReEfnWrX »
You could also try setting a portal password using just letters and numbers. Maybe there is an issue with using one of the special characters that you are using? Worth a shot to rule that out?
