Internal Memory Leaves LED's at 1%
Related to the Portal
PostPosted: Mon Feb 03, 2014 9:33 pm
So I received my Wifi module today and got it working!!! :D So I started using the internal memory to control my PWM expansion. I have been using my PWM expansion for months no problem but now when they should be off they sit at 1%. I am not sure because the light schedule is noon to 10 PM and at 10 they all went to 1% instead of zero. am I missing something? currently I used the http:yourip:2000/wifi to override to 0, then cancel over ride and they stayed at zero. Any Input on what this could be?
Also on a side note is there a way to set different channels to come on at different times with internal memory through the portal? like make channel 2 actinic so it turns on 30 minutes before and stays on after the rest? I am assuming it can be done just not with the wizard doing the programming for me.
Drew
PostPosted: Mon Feb 03, 2014 9:42 pm
Can you post your code?
PostPosted: Mon Feb 03, 2014 9:53 pm
Its nothing special straight wizard.. hopefully I will learn to make some custom code myself soon so I don't have to relay on the basics of the wizards.
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port5Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port5Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.SingleATOLow( Port4 );
ReefAngel.MoonLights( Port5 );
ReefAngel.PWM.Channel2PWMParabola();
ReefAngel.PWM.Channel3PWMParabola();
ReefAngel.Portal( "Drew471" );
PostPosted: Mon Feb 03, 2014 9:57 pm
Make sure that you have 0 in the end% of the channel you are saying it is ending at 1%.
For the actinic offset, try this:
ReefAngel.PWM.Channel0PWMParabola(30);
PostPosted: Mon Feb 03, 2014 10:14 pm
Roberto do you mean start %? Of the channels? Isn't end% what I reaches in the middle of its cycle? According to your dimming waveforms charts. They all had a start % of 0
The (30) stands for 30 minutes assuming.
I will try messing around more tomorrow night and see if it happens again.
Sent from my SPH-L720 using Tapatalk
PostPosted: Tue Feb 04, 2014 9:48 am
Yeah... sorry.. start %.
Yes, the 30 is the number of minutes that you want to offset the parabola both in the beginning and end of the parabola.
PostPosted: Tue Feb 04, 2014 4:43 pm
What is the memory location that is used for Dimming% when you override your Relay ports to on? I remember stumbling across this but cannot find it.
My Dimming channels always go up to 20% after my light schedule ends. He might have it set to 1?
PostPosted: Tue Feb 04, 2014 5:02 pm
What you mentioned is only applicable to standard dimming ports.
It could be reminiscence of the parabola function on an 8bit processor.
If you can't get it to work, you will need to change the function to this:
ReefAngel.PWM.SetChannel(0,PWMParabola(
      InternalMemory.StdLightsOnHour_read(),
      InternalMemory.StdLightsOnMinute_read(),
      InternalMemory.StdLightsOffHour_read(),
      InternalMemory.StdLightsOffMinute_read(),
      InternalMemory.PWMSlopeStart0_read(),
      InternalMemory.PWMSlopeEnd0_read(),
      0
That will force the channel to output 0 when the waveform is completed.
The last zero is what defines what the % is when you are outside the waveform.
PostPosted: Thu Feb 20, 2014 6:05 pm
So I checked and it still hangs at 1% unless I hit reboot on my andriod App. So any easy fix would be to have the system reboot when the lights are suppose to go off. What is the code to make the system reboot at time X?
PostPosted: Thu Feb 20, 2014 8:01 pm
According to your chart, it goes to zero.
Does it show on the screen 1%?
Next
Return to Portal
