Hello,
i have the wifi module configured and working fine (i can check it through windows client and through http://ipwifi)
but the portal shows unreachable access
i can connect to my public IP from internet on port 2000 and it works fine
http://waelaase.no-ip.info:2000/wifi
i'm not sure what is he problem
portal not updating from wifi
[img]/status/banner_3.aspx?id=waelaase&t=2[/img]
Re: portal not updating from wifi
You need to assign your Wifi unit a static IP address in your router settings and then configure port forwarding to that port.
Your wifi units local IP address has most likely changed.
If its working through the no-ip link. I could connect...that means his forwarding and internal ip are fine.
I'm not sure what his problem is either.
Do you have this line in your code?
ReefAngel.Portal("waelaase");
