Portal not updating
Portal not updating
Portal is showing last update of March 2nd but that connection is live, every once and a while when I log in it has updated info but goes right back to March 2nd.
Re: Portal not updating
I think your controller is not sending data to the portal.
Did you setup a port alley?
Yes I can, and just now the portal is now updated. We will see how long that lasts.
Edit for one refresh than it went back to March 2nd
Ok if I stay on the page for the first auto update the dashboard will show current information but the logging is not working in the web chart or relay activity.
I think it has something to do with the storm coderimai wrote:I think your controller is not sending data to the portal.
#define SIMPLE_MENU
#define NUMBERS_8x16
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
byte x = 6;
byte y = 2;
byte t;
char text[7];
//static byte vtechmode=0;
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawLargeText(3,255,8,16,"Redneck Reefin!", Font8x8);
ReefAngel.LCD.DrawLargeText(3,255,8,56,"Jason & Sarah's", Font8x8);
ReefAngel.LCD.DrawLargeText(3,255,32,65,"Money Pit", Font8x8);
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
ReefAngel.LCD.DrawText(0,255,10,30,"TANK");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 40, text, Num8x16);
ReefAngel.LCD.DrawText(0,255,100,30,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 85, 40, text, Num8x16);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.DrawText(0,255,8,109, "CWLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
//ReefAngel.PWM.GetDaylightValue(),
ReefAngel.LCD.DrawText(0,255,88,108, "RBLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119, ReefAngel.PWM.GetActinicValue());
//ReefAngel.PWM.GetActinicValue());
//ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port3 ) );
ReefAngel.ActinicLights( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.Wavemaker1( Port5 );
ReefAngel.Wavemaker2( Port6 );
// Calculate your regular sunrise/sunset PWM value
ActinicPWMValue=PWMSlope(14,0,23,0,15,100,60,ActinicPWMValue);
DaylightPWMValue=PWMSlope(14,15,22,15,11,100,60,DaylightPWMValue);
CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(15,30)
#define End_Cloud_Before NumMins(22,00)
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,15,180);
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.DrawText(0,255,10,99,"C");
ReefAngel.LCD.DrawText(0,255,16,99,"00:00");
ReefAngel.LCD.DrawText(0,255,50,99,"L");
ReefAngel.LCD.DrawText(0,255,56,99,"00:00");
int x=0;
if ((cloudstart/60)>=10) x=16; else x=22;
ReefAngel.LCD.DrawText(0,255,x,99,(cloudstart/60));
if ((cloudstart%60)>=10) x=34; else x=40;
ReefAngel.LCD.DrawText(0,255,x,99,(cloudstart%60));
ReefAngel.LCD.DrawText(0,255,95,99,cloudduration);
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=56; else x=62;
ReefAngel.LCD.DrawText(0,255,x,99,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=74; else x=80;
ReefAngel.LCD.DrawText(0,255,x,99,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
ReefAngel.Portal( "jegillis" );
#define SIMPLE_MENU
byte x = 6;
byte y = 2;
byte t;
char text[7];
Try this:
#define SIMPLE_MENU
byte x = 6;
byte y = 2;
byte t;
char text[7];
CheckCloud();
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
int x=0;
int x=0;
cstart*=60;
cend*=60;
that fixed it, thank you!
im having the same issue. What was done to fix that?
Your problem was that you set a portal security and your code doesn't have one.canitolindo wrote:im having the same issue. What was done to fix that?
I went ahead and disable it for you. It should be updating now.
