override notification?
Can the portal email me when a port is overridded? Can a trigger do that? If so, how?
Re: override notification?
You would need to use custom variables to do that.
Assign the state of the port override to a custom var and trigger the portal on the value of the custom var.
I'll try to put a code together when i get a chance.
This post gives you an idea of what I wanted to say
http://forum.reefangel.com/viewtopic.php?p=37341#p37341
