Relay Activity
Relay Activity
If RA only contacts the portal every 5 minutes, does it only show the relay activity at that point in time, or is there a buffer? I ask because my swabby comes on for 2 minutes every six hours, but it shows only once a day on average. Same with my ato. When first programmed, they showed a lot more spikes on the relay page, but I guess they are just not on when the RA contacts the portal at the moment?
Re: Relay Activity
If you look for LogDosing i have some code to keep track of the status of a relay but its a little bit of coding...
Re: Relay Activity
OK. Now I don't need to panic when it doesn't show on the page. Its the first time leaving the tank since its had water in it and I was nervous that things were still working as planned.
- Rodasphoto
- Contact:
Re: Relay Activity
I am thinking about dosing carbon and would like to track it. How do you track it?lnevo wrote:If you look for LogDosing i have some code to keep track of the status of a relay but its a little bit of coding...
Sent from my SCH-I535 using Tapatalk
