I created a no-ip address to link my Reef Angel to.
When I update my User Profile with this info it works correctly.
no-ip account using port 81 (I configured service port to 81 and internal port to 2000)
However when I log into Portal the next time the address changed to an ip address (in numbers) and ends in :z:81 or in ::81 and hence the address is unreachable.
Any idea how to fix this?
Portal changing Reef Angel wifi address
Re: Portal changing Reef Angel wifi address
It's a bug in the portal
You need 4 digits for the port.
Try setting the port to :0081
