Portal is not updating
Guys. my portal has been acting up for a little over a month now. When I first opens up it shows the data for Mar 24. After a few mins it will update to current but on every refresh it will do the samething. B\c of this my android app goes haywire to the point that i cant use the phone App. Please help
I have attached the image below:
Re: Portal is not updating
Looks like you are not sending data since march 24th then.
Did you change any code then? Can you post your current code that is loaded.
byte myRFMode=0;
byte myRFDuration=0;
byte myRFSpeed=0;
// Ports toggled
ReefAngel.WaterChangePorts = Port3Bit | Port7Bit| Port8Bit| Box1_Port1| Box1_Port4| Box1_Port6; // Turn off Return, UV, Skimmer, Heater, Sump Equipment, ATO
ReefAngel.FeedingModePorts = Port3Bit | Port8Bit; // Turn off Return and Skimmer
ReefAngel.LightsOnPorts = Port2Bit | Box1_Port2; //Turn on ATI lights, Fan and Fuge Light
ReefAngel.OverheatShutoffPorts = Port4Bit |Box1_Port1; // ATI Lights and Heaters
InternalMemory.OverheatTemp_write( 825 ); // Set the Overheat temperature setting
//Box1
ReefAngel.Relay.Off(Port1); // Port1 Acropower Dosing ...
ReefAngel.Relay.Off(Port2); // Port2 Fuge Light
if (hour()>=23 && hour()<7) ReefAngel.Relay.On(Port2); // Fuge Between 11pm-7am turn the relay on
ReefAngel.Relay.On(Port3); // Port3 Return Pump -- Always on
ReefAngel.Relay.Off(Port4); // Port4 Not Used
ReefAngel.Relay.Off(Port5); // Port5 Not Used
ReefAngel.Relay.Off(Port6); // Port6 Not Used
ReefAngel.Relay.On(Port7); // Port7 UV Lamp -- Always on
ReefAngel.Relay.DelayedOn( Port8,5 ); // Port8 Skimmer -- 5 min delay start
//box 2 (Box1_Portxx)
ReefAngel.StandardHeater( Box1_Port1,778,790 ); // Box1_Port1 Heater
ReefAngel.Relay.On(Box1_Port2); // Box1_Port2 Razor_LED (Sump) -- Always on
ReefAngel.Relay.Off(Box1_Port3); // Box1_Port3 Not Used
ReefAngel.Relay.On(Box1_Port4); // Box1_Port4 Sump Equipment-- Always on
ReefAngel.Relay.On(Box1_Port5); // Box1_Port5 MP40s -- Always on
// ReefAngel.Relay.Off(Box1_Port6); // Box1_Port6 ATO Top off (RODI)
ReefAngel.SingleATO(true,Box1_Port6,300,0); // ATO Low port with 60 seconds timeout
// ReefAngel.SingleATOHigh(true,Box1_Port6,300,0); // ATO Low port with 5 min timeout (200 mls per min, 3,785mls in a gallon)
ReefAngel.Relay.Off( Box1_Port7); // Box1_Port7 ALK Doser
ReefAngel.Relay.Off( Box1_Port8); // Box1_Port8 Calc Doser
// Old Code
//moonlight dimming
// if (hour()>=6 && hour()<10) ReefAngel.PWM.SetDaylight( PWMParabola(6,0,10,0,9,100,9) ); // Moonlight Between 5-10am turn the relay on
// if (hour()>=20 && hour()<=23) ReefAngel.PWM.SetDaylight( PWMParabola(20,0,23,0,100,0,100) ); // From 8pm-Midnight turn the relay on
// else ReefAngel.PWM.SetDaylight(0);
// ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port4 ) ); //Refuge opposite of Actinic
// ReefAngel.Relay.Off( Box1_Port3); // Start with the relay off Port #11 Moonlight
//if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Box1_Port3); // Moonlight Between 5-10am turn the relay on
//if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Box1_Port3); // From 8pm-Midnight turn the relay
// ReefAngel.PWM.SetDaylight( PWMSlope(20,0,23,0,100,0,180,100) );
// ReefAngel.PWM.SetDaylight( PWMSlope(6,0,10,0,9,100,240,9) );
//ReefAngel.Relay.off(Box1_Port3);
// if (hour()>=10 || hour()<20) ReefAngel.PWM.SetDaylight(0);
// ReefAngel.PWM.SetDaylight( MoonPhase()+10 );
// ReefAngel.PWM.SetDaylight(PWMParabola(20,0,23,0,0, MoonPhase(),0 ));
//ReefAngel.PWM.SetDaylight(PWMSlope(6,0,23,0,0,100,240,0));
//if (hour()>=5 && hour()<20) ReefAngel.PWM.SetDaylight(0);
//ReefAngel.PWM.SetDaylight( PWMParabola(20,0,23,0,100,0,100) );
//ReefAngel.PWM.SetDaylight( PWMParabola(6,0,10,0,9,100,9) );
if (hour()>=6 && hour()<11)
myRFSetMode(ReefCrest,85,10);
else if (hour()>=11 && hour()<13)
else if (hour()>=13 && hour()<16)
myRFSetMode(Smart_NTM,85,50);
else if (hour()>=16 && hour()<19)
myRFSetMode(ReefCrest,65,10);
myRFSetMode(Lagoon,40,10);
// Hardcode PH calibrations
//ReefAngel.PHMin=544; // PH7.0
//ReefAngel.PHMax=830; // PH10.0
RunDosingPumps();
LogDosingPumps();
ReefAngel.Portal( "ecam" );
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Salinity:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,75,93,text);
ReefAngel.LCD.DrawOutletBox( 12, 94, TempRelay );
// Define Your dosing pumps
#define numDPumps 3
byte pumpRelays[numDPumps]={ Box1_Port7, Box1_Port8,Port1Bit};
int DPVolume[numDPumps]={ 17, 17, 7} ; // 1ml for each alk and calcium - total volume for the day
int DPRepeat[numDPumps]={ 360, 360, 360 } ; // Repeat every 4 hrs 6x a day --- in mins
// Define Calibration here
int CalTime[numDPumps]={ 600, 600, 600 }; // 10 minutes / 10 minutes
int CalVol[numDPumps]={ 350, 300,384 }; // 350ml / 300ml... .58 / .5/.64
// Function: RunDosingPumps()
void RunDosingPumps() {
float rate;
int calcTime[numDPumps];
for (int i=0;i < numDPumps; i++) {
rate=(float)CalVol[i]/CalTime[i];
calcTime[i]=DPVolume[i]/rate/(1440/DPRepeat[i]);
// Run the pumps
ReefAngel.DosingPumpRepeat(pumpRelays[i], i*5, DPRepeat[i], calcTime[i]); // Offset between each pump is 5 minutes
// Display Time calculated in portal
ReefAngel.CustomVar[0]=calcTime[0];
ReefAngel.CustomVar[1]=calcTime[1];
ReefAngel.CustomVar[2]=calcTime[2];
// Function: LogDosingPumps()
void LogDosingPumps() {
static time_t pumpTimer[numDPumps];
static boolean pumpStatus[numDPumps];
float rate;
for (int i=0;i< numDPumps;i++) {
if (ReefAngel.Relay.Status(pumpRelays[i])) {
if (!pumpStatus[i]) {
pumpTimer[i]=now()-pumpTimer[i]; // Pump was off, timer is now a time
pumpStatus[i]=true;
if (pumpStatus[i]) {
pumpTimer[i]=now()-pumpTimer[i]; // Pump was on, timer is now a timer
pumpStatus[i]=false;
// Report How much volume has been dosed per day.
// Could make this in minutes... excercise for the reader..
ReefAngel.CustomVar[3]=pumpTimer[0]*rate;
ReefAngel.CustomVar[4]=pumpTimer[1]*rate;
ReefAngel.CustomVar[5]=pumpTimer[2]*rate;
// Clear timer at end of day
if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[i]=0;
void myRFSetMode(byte m, byte s, byte d)
if (m!=myRFMode || s!=myRFSpeed || d!=myRFDuration || millis()<5000)
myRFMode=m;
myRFSpeed=s;
myRFDuration=d;
ReefAngel.RF.SetMode(m,s,d);
Also Lee and roberto,
Can you tell me how this is possible based on my previously posted code that calls for 17 mls of dosing....
- Capture.PNG (9.26 KiB) Viewed 8030 times
We'll first off your pumpArray declaration is wrong. You need to use Port1 not Port1Bit...
I fixed that. but what is overdosing is the Calc and Alk port7 and port 8
Thank you!!!
I just checked my portal and it looks like the Custom variables are not changing. By 9am. my volume should be the same as the time. However it is still showing 49 and 56. But the rest of the portal is updating just fine (i can toggle switches and graphs seem okay.
Your RA is not sending data to the portal it sounds like, but port forwarding it working and your RA is responding on the network.
Did you reuse one of the built on timers anywhere?
Yeah, your RA has not sent data to the portal since March still..
<MYREEFANGELID>ecam</MYREEFANGELID>
<LOGDATE>3/25/2014 3:40:53 AM</LOGDATE>
Either the outgoing data is blocked, you removed ReefAngel.Portal() from your code, or you re-used the portal timer for something else. Let me look through your code...
I don't see anything in the code that would block the portal updates.... but your definitely not sending... Did you set a portal key in the portal settings?
But Lee,
If you wait about 2 mins. The page updates correctly and allow me to toggle switchs. However after every toggle it takes 2 mins as the date resets to the 3/25 and then resets to May 1.
[img] [/img]
[img] [/img]
Nolnevo wrote:I don't see anything in the code that would block the portal updates.... but your definitely not sending... Did you set a portal key in the portal settings?
[img] [/img]
No, there is 2 sets of communication we are talking about...
1) Portal -> RA (happens when you log in and want to switch relays/update memory)
This is the one that requires port forwarding to get back inside your network.
2) RA -> Portal (happens every 5 minutes from the RA. Sends your parameters to the portal)
This is the data that is stored in the DB and shows up when you first log in.
You have #1 working. When you log into the portal it first shows data from #2 and then refreshes after you've loaded the page. This is why you see good data after waiting 2 minutes.
#1 is usually the hard one to setup since it requires port forwarding. For #2 the only other thing it could be is the IP address for the portal may have been screwed up. Did you change anything on your wifi module around that time? I'll let roberto chime in on what parameter it is your looking for. I think if you can get a "get e" on your wifi module it would help to determine if I'm on the right track.
Looks like to be the wifi attachment.
You will need to either get the dump from the wifi module with "get e" command or plug the usb-ttl cable and use the Serial Monitor on Arduino.
Please explain?. Should I essentially uninstall and then re-install the wifi module?
It worked guys. Thanks for all the help. I am now updating to the portal. I did the factory reset
