Alternative Dynamic DNS
Posted: Thu Jul 10, 2014 10:42 am
With the issues that occurred using no-ip's free dynamic dns last week, I decided to revisit another alternative ddns from a year ago. I looked into freedns.afraid.org. This website allows you to utilize a dynamic dns service for free. They allow domain owners to register a domain with them for it to be used by others, for free. All that you must do, is create an account with them and then you can start using their service (provided you agree to their terms of use).
There are a few things that I liked about this service:
  • It's free, no cost to the person using it.
  • They have lots of updater clients available to use and have built in functionality with DD-WRT's router firmware (which I personally use).
  • You are not limited to their choice of domain names. So, if you wanted a different domain name to use, you could purchase it and then allow them to place it in their pool of domain names for others to use.
  • They do not have a requirement to "login" to their site every 30 days in order to keep your host active. As long as your update clients are working and you are not causing any harm or violating any terms, your host stays active. You "might" have to login to their site once every 6 months if there is no activity on their servers, but I am not 100% positive.
  • You can have more than 2 or 3 subdomains. I am not positive on the amount of subdomains you can have, but it can be more than the other alternatives.
  • Their update clients utilize a token scheme for updating. So you don't have to store/save your username/password in your settings of the client. This way you can have a really complex password and not have to worry about typing it exact. If you ever felt like your tokens have been compromised, you can safely regenerate them and then update your update clients....all without having to change your password on your account on the website.
So far, I've been using the service for about a week and I have been pleased with it. Updates have been very fast and I have not had any issues resolving the IP's, etc. I have 3 subdomains setup already.
I purchased a domain, tank-stats.com, for use with the system. I have allowed it to be used by whomever wants to use it. I just ask that it be used for something related to fish tank controllers (it doesn't have to be solely for the RA community, it could be for other controllers or uses as well). I plan on keeping the domain in their system as long as I can and as long as their is a need for it.
If you want to use it, you just need to do this:
  1. Goto http://freedns.afraid.org and signup for an account.
  2. Browse the shared registry and search for tank-stats.com
  3. Click on tank-stats.com to add a new subdomain
  4. Enter your subdomain name and put in your destination (your system's public IP should be filled in already).
  5. Click Save and your domain is setup.
  6. Then you need to click on Dynamic DNS and look for the Dynamic DNS Clients to use.
That's it. It's as simple as that. There are 2 clients that are recommended for windows (one is a service and the other is a standalone app) plus a myriad of other updater clients.
If you have any questions, feel free to ask.
Like I said earlier, you are welcome to use this or not. It will not affect me at all. I am using it myself and will continue to use it. My main goal is to be able to provide another alternative for people to use...that's all.
If you have any concerns about the service/domain not being available in the future, hopefully my track record with this community will speak for itself and that I'm not planning on going anywhere.
Re: Alternative Dynamic DNS
Posted: Thu Sep 08, 2022 5:52 pm
by howaboutme
Old thread but wanted to check to see if tank-stats.com is still working? I was using this for port forwarding but all of a sudden it didn't work for the last day. After a few tests, I changed the domain to something else and it worked. That's why I'm asking of tank-stats.com is still up. If you've closed it, I want to say "thank you"! :D
Posted: Mon Sep 12, 2022 3:47 am
howaboutme wrote:Old thread but wanted to check to see if tank-stats.com is still working? I was using this for port forwarding but all of a sudden it didn't work for the last day. After a few tests, I changed the domain to something else and it worked. That's why I'm asking of tank-stats.com is still up. If you've closed it, I want to say "thank you"! :D
it's still up and running. I'm not sure what happened for you. I still see your domain in there.
Sent from my Pixel 6 using Tapatalk
Posted: Mon Sep 12, 2022 4:35 am
by howaboutme
Ok, no worries. I'll double check.
