Our DDNS service
Related to the Portal
PostPosted: Sun Jan 04, 2015 9:46 am
Roberto, could you update the original post and make this a sticky? It will certainly help the new folks.
PostPosted: Sun Jan 04, 2015 10:21 am
Sacohen wrote:Yes it did. There was a problem with the android app or the portal with the "_".
the character violated the dns name specifications, so the character was changed to be in compliance with the dns standards.
Sent from my Nexus 7 using Tapatalk
PostPosted: Sun Jan 04, 2015 10:25 am
cosmith71 wrote:Roberto, could you update the original post and make this a sticky? It will certainly help the new folks.
i just updated the OP and changed the "_" to "-" and made the topic a sticky.
PostPosted: Sun Jan 04, 2015 10:31 am
Thanks, Curt.
PostPosted: Mon Jan 19, 2015 10:52 pm
I'm still having problems with my portal. i cant seem to access it outside of the app or on reef angel website. ive tried posting my ddns into the address bar and even tried the ip address for my wifi attachement. im lost
PostPosted: Tue Jan 20, 2015 4:11 am
vvjosh06 wrote:I'm still having problems with my portal. i cant seem to access it outside of the app or on reef angel website. ive tried posting my ddns into the address bar and even tried the ip address for my wifi attachement. im lost
The Portal (website) and the apps are the only ways to access your RA right now. Accessing the controller directly is still in beta and doesn't work very well.
PostPosted: Tue Jan 20, 2015 5:18 am
If you want to access it directly add /r99 to the URL (http://www.xxx.yyy.zzz:2000/r99)
If this works with your internal IP and not your external IP then your port forwarding is not working
PostPosted: Wed Jun 10, 2015 4:36 pm
I changed my subdomain from the default in a continuing set of things I'm doing to improve security a bit. Anyone know how quickly it gets updated by the RA server in the zone file?
Edit: It gets updated right away if you get the ReefAngel.Portal() syntax right. I forgot to put a comma between the username and portal key, so it never took affect until I fixed it. Doh.
PostPosted: Thu Apr 21, 2016 7:25 am
I am SO confused with out to make my RA accessible from anywhere outside of my network. I do not understand all of the jargon(dns, tcp, ymca, smtp). So far I have not found a thread that helps in simple terms how to set this up. i contacted reef angel and the guy has helped me with the wifi box connecting but he doesnt have any support for the port forwarding. i have a netgear router and i added the ports and ip address to port forwarding but still it doesnt work i have to assume its not as easy as typing in the port and ip address. because i did that and it doesnt work so there must be more to it. can anyone help with this? im willing to trade a zoa frag for information if need be.
PostPosted: Thu Apr 21, 2016 7:31 am
What model Netgear router?
I want to try information on it online.
Sent from my SM-G928P using Tapatalk
Return to Portal
