CustomVar
Related to the Portal
windsweptfarm
CustomVar
Post by windsweptfarm »
Is there a way to give the custom variables used for portal notifications meaningful labels? I would like to relabel them like I am able to label the relays and water level sensors in the portal. Much easier to understand what is going on when glancing at the iPhone app if the variables were labeled instead of indicating that CustomVar[0] is set to1 for example. Maybe this is already available and I just can't figure out how to do it. I've seen in some of the member's PDE's what looks like CustomVar[with a name besides [0] 0r [1]] for example, but I have not been able to do this.
windsweptfarm
Re: CustomVar
Saw that you set up support for labeling the custom variables in the portal. Thanks so much.
Casey
