No chart info
No chart info
My portal is acting up and doesn't have any info for the Web Chart or Relay Activity even though it's showing connected and it's said the same thing for the past week. Any ideas?
Re: No chart info
The last time your controller sent data was on 09/03
Did you change your code around that time?
Re: No chart info
I did. But the weird thing is that it shows as connected on my portal.
My reefangelid: alexwbush
Connection Status: Ready
Last Update: 9/15/2014 9:58:15 AM
Displaying data from: Reef Angel Controller (live)
And I can turn on/off things no problem.
Re: No chart info
That's because your port fowarding is working, but your RA is not "sending" data to the portal which gets recorded for the charts. You're only getting the live update...
Did you change your code? Can you post the current version you have.
Re: No chart info
hahahahaahahaha! sorry, nevermind. I figured out what it is when looking at the code. It's reporting to an old name I used for a temporary tank. I'll update and it should work. Thanks!
