Hi All - I noticed that my portal notifications are not working
I check that there is communication to the portal - all the settings are correct. I checked that I have my text number and email address separated by a comma.
It shows the last notification sent was on 9/9/2014.
I should get one a day when I do my feedings - my return goes off and my sump water level gets high triggering a notification.
It used to work. I don't think I changed anything.
I've attached the water level chart. I should get a notification when WL1 goes above 125.
Any thoughts?
Portal Notifications not working
- webchart.png (49.92 KiB) Viewed 4635 times
Re: Portal Notifications not working
Let's try this:
Go to the portal and chick on the edit button for the trigger you are referring too.
You will see that the name and description will be null. Change it to something else, save it and see if you get the email when wl1 goes above 125.
Will do. Thx!
That did it! Thanks!rimai wrote:Let's try this:
