Notification for ATO Low
Posted: Mon Nov 10, 2014 11:23 am
by howaboutme
Hi all,
I'm trying to set up an email notification trigger for anytime the ATO low is on. What value do I input in the box after I select "ATO Low Port" and then "=" (or something else?) and "_____________"?
Re: Notification for ATO Low
Posted: Mon Nov 10, 2014 12:55 pm
by Sacohen
On the Andriod App 1 = on and 0 = off.
I'm assuming the Portal and U-App are the same.
Posted: Mon Nov 10, 2014 1:45 pm
by howaboutme
Thanks! I'll give it a test tonight.
Posted: Mon Nov 10, 2014 7:03 pm
by howaboutme
Well..I realized that this won't work for my purpose because the portal doesn't ping the unit in real time....Oh well..
What I was thinking of doing is to get notification each time my ATO goes off. First, since this is a new thing, to double check that everything works and 2nd, just to see how often it goes off in a period of time. If anyone has another, hard coded, way, please let me know!
Posted: Tue Nov 11, 2014 6:31 am
by Sacohen
The notifications on the Android app are not real time,but are still a little more frequent then the portal is.
Posted: Tue Nov 11, 2014 8:12 am
You can use WiFiAlert Jack. There should be sample code in my INO. You pretty much initialize it and then use a Send function to trigger the alert. The only issue with this is the frequency of the alert. Default is 15 minutes. You can set a flag on the send to ALWAYS send but you have to be careful because it could easily send you a thousand messages if your not careful. And you may need the dev libraries, I forget when it got added, but it should be there I think...
Posted: Tue Nov 11, 2014 8:14 am
You could set the frequency as low as once per minute which would help, but if the ATO kicks in every 30 seconds for example it will only alert you every other time.
Posted: Tue Nov 11, 2014 1:54 pm
by howaboutme
Thanks Lee. I will take a look at your code later. Once a minute frequency would work. My timeout is at 8 minutes so it has to be sooner than that.
I will look and then ask questions. Thanks all.
Sent from my Galaxy Nexus using Tapatalk
Posted: Tue Nov 11, 2014 2:16 pm
If you need it within the 8 minutes, then normal portal alert would work. RA sends data to portal every 5
Posted: Tue Nov 11, 2014 3:58 pm
by howaboutme
Okay, the five minutes may work. I thought it was more than that. I still want to see what you did though. Thanks!
Posted: Wed Nov 12, 2014 7:06 am
by howaboutme
Lee...Looked over your code a bit last night. I saw the wifialert but that's where my understanding stopped. Need some more direction...pleeeeaassseeee.....
Posted: Wed Nov 12, 2014 8:27 pm
static WiFiAlert myAlert;
myAlert.SetDelay(3600); // send every hour, default is 15 minutes
// Turn off Skimmer if waste collector is full.
if (ReefAngel.LowATO.IsActive()) {
myAlert.Send("Skimmate+container+full!+Skimmer+disabled.");
ReefAngel.Relay.Override(Skimmer,0);
Posted: Sat Nov 15, 2014 9:13 am
by howaboutme
Thanks Lee. After a few days, I've noticed that the portal notifications work fine for me. Since it's every 5 minutes, my ATO will run somewhere in between that and it has triggered the alert each time. I'll keep my code simple for now.
Posted: Sat Nov 15, 2014 7:09 pm
by howaboutme
Another question..I want to add a delay after wc mode.
Can I just add this (time is controlled by portal):
ReefAngel.Relay.DelayedOn( Port1 )
After this:
So it looks like this:
ReefAngel.Relay.DelayedOn( Port1 );
ReefAngel.DayLights( Port3 );
ReefAngel.ActinicLights( Port4 );
ReefAngel.Relay.DelayedOn( Port5 );
ReefAngel.DosingPumpRepeat1( Port6 );
ReefAngel.StandardHeater( Port8 );
Since I already have port 5 on delay start, can I combine port 1 into the same line or vice versa or does each port have to have it's own? Thanks!
Posted: Sun Nov 16, 2014 4:18 am
It won't work.
The last line would always take effect ad disregard the previous ones.
So, ReefAngel.SingleATOLow( Port1 ); would never do anything.
Posted: Sun Nov 16, 2014 5:05 am
Each would need its own line and if you repeat a port like that as Roberto said, they overwrite each other. We'll have to write a timer and have an if else to have it control the ATO. I'll throw together some code later
Posted: Sun Nov 16, 2014 7:04 am
by howaboutme
Is it something similar to this:
static time_t wcTimer;
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
if (now()-wcTimer > 0 && now()-wcTimer < 600) {
ReefAngel.Relay.Off(Port8);
} else {
ReefAngel.WaterLevelATO(Port8,720,0,1);
Except replace this:
With this:
And adjust the time to whatever I want?
Posted: Sun Nov 16, 2014 7:59 am
Yes exactly. Except the first { is an artifact of wherever you got it from.
Posted: Sun Nov 16, 2014 3:18 pm
by howaboutme
Thanks. I'll give a shot but realized something last night during my water change.
I put the relay that the ATO pump is on to off during wc. I realized that after the water change, my ATO clear was triggered. In theory, if the ATO clear is triggered each time, why would I need to do the time delay if I need to manually clear the ATO anyways? Am I thinking about this way too deeply?
Posted: Sun Nov 16, 2014 4:46 pm
Did you have it in ReefAngel.WaterChangePorts? Not sure I follow the sequence.
Posted: Sun Nov 16, 2014 6:12 pm
by howaboutme
lnevo wrote:Did you have it in ReefAngel.WaterChangePorts?
Yes, it's part of it.
