Web portal and banner update issue
Related to the Portal
PostPosted: Tue Dec 30, 2014 7:22 am
stare at least 20min, nothing happened in monitor window.
is there anything wrong with my RA+?
PostPosted: Tue Dec 30, 2014 7:52 am
Were you using teraterm or the Serial Monitor inside the Arduino app. Can you post your full code. Can you upload the code again and then monitor again via the serial monitor.
PostPosted: Tue Dec 30, 2014 7:58 am
my code as attached
// Define Relay Ports by Name
#define Return             1
#define ATOPump            2
#define Skimmer            3
#define Wavepump           4
#define None1              5
#define ZeovitShake        6
#define Relay_Box2         7
#define Heater             8
#define T5_Channel1        Box1_Port1
#define T5_Channel2        Box1_Port2
#define T5_Channel3        Box1_Port3
#define ZEO_ST3            Box1_Port4
#define ZEO_SP             Box1_Port5
#define CaHCO3             Box1_Port6
#define ZEO_BB             Box1_Port7
#define ZEO_KB             Box1_Port8
// Define Custom Memory Locations
    ReefAngel.SetTemperatureUnit( Celsius );  // set to Celsius Temperature
    ReefAngel.FeedingModePorts = Port8Bit | Port4Bit | Port1Bit | Port2Bit;
    ReefAngel.OverheatShutoffPorts = Port8Bit;  //should be redefine to new ports
    ReefAngel.Relay.On(Return);
    ReefAngel.Relay.On(Wavepump);
    ReefAngel.Relay.On(Relay_Box2);
    ReefAngel.CustomLabels[0]="ReturnPump";
    ReefAngel.CustomLabels[1]="ATOPump";
    ReefAngel.CustomLabels[2]="Skimmer";
    ReefAngel.CustomLabels[3]="Wavepump";
    ReefAngel.CustomLabels[4]="None1";
    ReefAngel.CustomLabels[5]="ZeovitShake";
    ReefAngel.CustomLabels[6]="Relay_Box2";
    ReefAngel.CustomLabels[7]="Heater";
  //single ATO
    ReefAngel.SingleATO(true,ATOPump,90,1);
    ReefAngel.StandardHeater(Heater);
    ReefAngel.Relay.DelayedOn(Skimmer);
    // T5 light setup
    //ReefAngel.MoonLights(LunaLED);
    ReefAngel.DosingPumpRepeat1(ZeovitShake);
    ReefAngel.StandardLights(T5_Channel2);
    ReefAngel.PWM.SetChannel(0,ReefAngel.Relay.Status(T5_Channel1)*100);
    ReefAngel.DayLights(T5_Channel1);
    ReefAngel.PWM.SetChannel(1,ReefAngel.Relay.Status(T5_Channel3)*100);
    ReefAngel.ActinicLights(T5_Channel3);
    ReefAngel.PWM.SetChannel(2,ReefAngel.Relay.Status(T5_Channel2)*100);
    //dosing pump setup
    ReefAngel.DosingPump(ZEO_ST3,1,22,31,28);
    ReefAngel.PWM.SetChannel(3,ReefAngel.Relay.Status(ZEO_ST3)*100);
    ReefAngel.DosingPump(ZEO_ST3,2,6,31,28);
    ReefAngel.DosingPump(ZEO_SP,4,22,32,40);
    ReefAngel.PWM.SetChannel(4,ReefAngel.Relay.Status(ZEO_SP)*100);
    ReefAngel.DosingPumpRepeat2(CaHCO3);
    ReefAngel.PWM.SetChannel(5,ReefAngel.Relay.Status(CaHCO3)*100);
    //wave pump setup
    if (now() % SECS_PER_DAY >= 9 * SECS_PER_HOUR && now() % SECS_PER_DAY < (9 * SECS_PER_HOUR + 10 * SECS_PER_MIN) )
            ReefAngel.DCPump.SetMode(Lagoon,90,20);//Set RW8 to 90% speed with  pulse in Lagoon Mode from 9:00~9:10
       else if (now() % SECS_PER_DAY >= (9 * SECS_PER_HOUR + 10 * SECS_PER_MIN) && now() % SECS_PER_DAY < 10 * SECS_PER_HOUR )
            ReefAngel.DCPump.SetMode(TidalSwell,90,20); //Set RW to 90% speed with 20ms pulse in Tidal Swell Mode
       else if (now() % SECS_PER_DAY >= 10 * SECS_PER_HOUR  && now() % SECS_PER_DAY < (10 * SECS_PER_HOUR + 30 * SECS_PER_MIN) )
            ReefAngel.DCPump.SetMode(ReefCrest,85,20);//Set RW8 to 85% speed with Lagoon Pulse Mode
        else if (now() % SECS_PER_DAY >= (10 * SECS_PER_HOUR + 30 * SECS_PER_MIN)  && now() % SECS_PER_DAY < (11 * SECS_PER_HOUR + 10 * SECS_PER_MIN) )
            ReefAngel.DCPump.SetMode(Lagoon,85,20);//Set RW8 to 85% speed with  pulse in Lagoon Mode
        else if (now() % SECS_PER_DAY >= (11 * SECS_PER_HOUR + 10 * SECS_PER_MIN)  && now() % SECS_PER_DAY < (12 * SECS_PER_HOUR + 0 * SECS_PER_MIN) )
            ReefAngel.DCPump.SetMode(LongPulse,85,30);;//Set RW8 to 85% speed with Long pulse Mode
        else if (now() % SECS_PER_DAY >= (12 * SECS_PER_HOUR + 0 * SECS_PER_MIN) && now() % SECS_PER_DAY < 15 * SECS_PER_HOUR )
            ReefAngel.DCPump.SetMode(TidalSwell,85,20); //Set RW to 85% speed with 20ms pulse in Tidal Swell Mode
        else if (now() % SECS_PER_DAY >= 15 * SECS_PER_HOUR  && now() % SECS_PER_DAY < (17 * SECS_PER_HOUR + 0 * SECS_PER_MIN) )
        else if (now() % SECS_PER_DAY >= (17 * SECS_PER_HOUR + 0 * SECS_PER_MIN)  && now() % SECS_PER_DAY < (18 * SECS_PER_HOUR + 30 * SECS_PER_MIN))
            ReefAngel.DCPump.SetMode(NutrientTransport,85,700);//Set WP40 to 90% speed with NutrientTransport Mode
        else if (now() % SECS_PER_DAY >= (18 * SECS_PER_HOUR + 30 * SECS_PER_MIN)  && now() % SECS_PER_DAY < (18 * SECS_PER_HOUR + 30 * SECS_PER_MIN) )
            ReefAngel.DCPump.SetMode(Lagoon,85,20);//Set RW8 to 80% speed with  pulse in Lagoon Mode
        else if (now() % SECS_PER_DAY >= (19 * SECS_PER_HOUR + 0 * SECS_PER_MIN) && now() % SECS_PER_DAY < 20 * SECS_PER_HOUR )
        else if (now() % SECS_PER_DAY >= 20 * SECS_PER_HOUR  && now() % SECS_PER_DAY < (22 * SECS_PER_HOUR + 30 * SECS_PER_MIN) )
            ReefAngel.DCPump.SetMode(ReefCrest,75,20);//Set RW8 to 70% speed with Lagoon Pulse Mode
        else if (now() % SECS_PER_DAY >= (22 * SECS_PER_HOUR + 30 * SECS_PER_MIN)  && now() % SECS_PER_DAY < (22 * SECS_PER_HOUR + 35 * SECS_PER_MIN) )
            ReefAngel.DCPump.SetMode(Lagoon,90,20);//Set RW8 to 90% speed with  pulse in Lagoon Mode, dossing coral feed.
            ReefAngel.DCPump.SetMode(NutrientTransport,40,30);
    static unsigned long feeding;
    if (now()-feeding<1*SECS_PER_HOUR) {
    //Autofeeder
    if ( ((hour() == 18)) && (minute() == 58) &&(second() == 30) ) ReefAngel.FeedingModeStart();
    //Skimmer off 1.5 hours when coral feeding.
    if (now()%SECS_PER_DAY >= (22 * SECS_PER_HOUR + 30 * SECS_PER_MIN)  && now()%SECS_PER_DAY < (23 * SECS_PER_HOUR + 30 * SECS_PER_MIN) )
      ReefAngel.Relay.Off(Skimmer);
   static boolean powerOutage=false;
  // Power Outage - turn off everything
  if (!ReefAngel.Relay.IsRelayPresent(MAIN_RELAY)) // Main Relay NOT present
    powerOutage=true;
    ReefAngel.Relay.Off(Return);
    ReefAngel.Relay.Off(None1);
    ReefAngel.Relay.Off(Wavepump);
    ReefAngel.Relay.Off(ZeovitShake);
    ReefAngel.Relay.Off(Heater);
    ReefAngel.Relay.Off(Relay_Box2);
    ReefAngel.Relay.Off(ATOPump);
  // Power Restored - Turn things back on
  if (powerOutage && ReefAngel.Relay.IsRelayPresent(MAIN_RELAY))
    LastStart=now();
    powerOutage=false;
    ReefAngel.Relay.On(Skimmer);
     // Turn off Skimmer if Return pump has been shutoff.
  if (!ReefAngel.Relay.Status(Return)) {
    ReefAngel.Portal( "sesame");
PostPosted: Tue Dec 30, 2014 8:11 am
lnevo wrote:Were you using teraterm or the Serial Monitor inside the Arduino app. Can you post your full code. Can you upload the code again and then monitor again via the serial monitor.
using Arduino Serial monitor. another 10 min. but nothing popup.
may have issue with my laptop?
PostPosted: Tue Dec 30, 2014 9:14 am
It is weird, because if you can upload codes, you should be able to get it to send data.
To make sure we are in the same page, upload this same above code one more time and right after upload, open Serial Monitor without disconnecting the cable or even touching it at all.
Do you get anything after 10 to 15mins?
If you do not, make sure that "Both NL & CR" is selected on the left side of the baud rate.
On the top part of the window, by the Send button, type "GET / HTTP" and hit enter.
Do you get anything now?
PostPosted: Tue Dec 30, 2014 9:22 am
Should also add some Serial.println as a test..
PostPosted: Tue Dec 30, 2014 9:33 am
Will have another try
PostPosted: Tue Dec 30, 2014 9:39 am
Your code looks fine, nothing that would interfere. Just an FYI though, you can't monitor for power outages with the main relay box since the RA will also lose power in that scenario. You can monitor your expansion relay boxes only.
PostPosted: Wed Dec 31, 2014 7:01 am
upload code again, and checked with buildin monitor, nothing happend at "both nl / cr"
type get / http shown message below:
HTTP/1.1 200 OK
Server: ReefAngel
Pragma: no-cache
Connection: close
Content-Type: text/html
Content-Length: 41
<h1>Reef Angel Controller Web Server</h1>
PostPosted: Wed Dec 31, 2014 8:31 am
ok so I/O is working.. very odd. Did you add a Serial.println as a test?
Return to Portal
