lnevo wrote:ok so I/O is working.. very odd. Did you add a Serial.println as a test?
how to, no idea. thank you
how to, no idea. thank you |
Add this in your loop:
Serial.println("test"); |
"test" popup crazy in monitor. is that means it works? |
Yeah. I would remove your libraries folder and re-install the ReefAngel installer at this point. Serial I/O is working and you can obviously communicate with the wifi module. Something is not right that the portal timer is not working. If a libraries re-install does not help, I would suggest regenerating a new basic code and testing.
Yes... You can remove that line now.
There doesn't seem to be any reason why your controller doesn't send data. Roberto.
Jesus!!!!
I spent all morning today trying to figure out why this wasn't working... Here is the offending line:
The timer 4 is in charge of sending data to the Portal. It never struck at me that you were using that function. I though that was a repeat dosing schedule for some reason. We need to change that function to not use timers at all. This is the same equivalent:
Try this out and let me know if that works for you. Roberto.
Awesome find! I was looking for it and it was completely hidden there
Wahoo!!
great new year gifts. ![]() ![]() ![]() change code as Roberto attached. got some thing from serial port. GET /status/submitp.aspx?t1=187&t2=223&t3=226&ph=793&id=sesame&em=1&em1=2&rem=1&bid=1&key=&ddns=&af=0&sf=0&atohigh=0&atolow=0&r=205&ron=0&roff=255&r1=4&ron1=0&roff1=255&pwma=90&pwmd=80&pwmao=255&pwmdo=255&pwme0=0&pwme0O=255&pwme1=100&pwme1O=255&pwme2=0&pwme2O=255&pwme3=0&pwme3O=255&pwme4=0&pwme4O=255&pwme5=0&pwme5O=255&dcm=1&dcs=85&dcd=20&dct=30 waiting half an hour to see if any changes from portal. sorry havent remember to change code this area. should be careful next time. but im thinking if possible to add more "DosingPumpRepert" function in lib and iOS App as well. easy to change and adjust by mobile device. |
portal and banner get back to work.
thank you for your support Roberto, Lee. appreciate and best support i've ever have. |
Glad it's working now! Happy New Year!
