Email alerts not working
Related to the Portal
PostPosted: Sun Jan 04, 2015 6:50 am
I brought my temp up to test email alerts and didn't get an email. At first thought I assumed there was a delay but after waiting serval hours I realized it's not working correctly.
1. Is this something I need to code into the controller or is adding it to the portal sufficient?
2. How long before email is sent? Noticed the portal starts 1 email an hour!
PostPosted: Sun Jan 04, 2015 7:21 am
Where are the notifications set up in the portal or on you phone app?
The portal updates every 15 min I believe so if the increase in temp is only for 1 min and the portal does not update at that moment then you won;t get a notification on it.
PostPosted: Sun Jan 04, 2015 7:44 am
That explains it. Thanks
Have another question while you're here. My doing pumps on port 1 are only on for 15 seconds a day but not showing up on the relay activity report in the portal. Is that because because they're on for a short interval? (Hope that's the case)
PostPosted: Sun Jan 04, 2015 8:57 am
Reefology wrote:That explains it. Thanks
yes.
Sent from my Moto X
PostPosted: Sun Jan 04, 2015 9:08 am
Exactly.
PostPosted: Sun Jan 04, 2015 9:22 am
5 minutes not 15 Steve
PostPosted: Sun Jan 04, 2015 9:24 am
Sorry. I forgot. Still the same situation applies. If the temp rises for a minute you could miss he update of he portal.
PostPosted: Sun Jan 04, 2015 10:48 am
Great thanks
PostPosted: Sun Jan 04, 2015 12:53 pm
I saw a post somewhere... That showed you how to setup a virtual relay triggered off your dosing pumps relay that was virtually open for five minutes to show it on portal...
Return to Portal
