DC pump question?
Posted: Fri Jan 16, 2015 9:38 am
Not sure my pump is running right.
1. In the portal dash board, if my dc pump mode is set to else (as an example), speed is set to 80 (still not sure what to set it to as modes dictate speed...i think?), and my PWM channel says 30%, what speed should i expect the pump to be running at...30% or 80%?
2. If i declare my PWM channels to "NONE", "SYNC'' or "ANTISYNC" how should they respond? and what are the differences?
